Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
Update - Group Buy 41:
- ARE31 (payment clear)
- poobah (payment clear)
- SandalsBoy (waiting for payment to clear)
Closing this weekend!
Quote for the following please for an R34 25GT Sedan Non-Turbo:
Front Slotted
Rear Slotted
EBC Greens to suit
EBC Reds to suit
And an ETA if possible please.
Postage to 4108
Thanks mate
Cheers
Nathan
Hi Rianto
Im definitely interested in purchasing the front slotted rotors to suit r33 GTS-t (7693s) and rear slotted rotors to suit r32 GTS-t (908s).
I'm after pads also, not to sure which colour i'm after. Car is mainly street driven with the odd day at the track only for drift practise days, not hot laps. Its a 32GTS-t with 220rwkw's.
Could you please sent me a quote on the price of pads and delivery costs of all the above items to Adelaide 5097.
Please include bank details of where to send the money.
I'd like to get a set of ADR approved braided brake lines. Do you sell these also or have any idea where to look for them.
Thanks Adam
pm sent - Update - Group Buy 41:
- SandalsBoy (payment clear)
- tiels32 (waiting for payment to clear)
Final list - will send this list off early next week after payment clears
Scandy, check your pm
- N-DAWG
Glad you liked it, I like them on the v as well...
They get better as they wear out a bit more (noise getting less and bite getting grippier)
- N-DAWG (payment clear)
Will send out tonight or tomorrow - just gonna double check the R34 non turbo rotor size and pads at the front, making sure it's the right part!
