hey all i just had my r32 dynoed at hyperdrive, when i bought it i was told it had about 299rwhp with a miss, i wasnt sure so i took it to hyperdrive this mourning with spitfire coils and only pulled 265.9rwhp at 14psi, the boost was all over the place, the guy at hyperdrive told me the hks 2540 wont really do anybetter than that :domokun: so anyway im gonna get a new turbo, any suggestions where to take it or what turbo to get??
cheers
bro theres rb25`s on the turbo upgrade section usen the same turbo for well over 300,
  • Replies 90
Posted Images
I had my car tuned this morning at Hyperdrive, its got a GT3082R with similar mods as urself. i went 330rwhp @ 16psi through a built auto box. had fuel issues so i could prob see 340 - 350 once sorted. i would go with the GT30 series ... they are not too laggy when tuned right, mine is very responsive and makes power through 7300rpm, pulls very, very hard =D
+ if yours is manual you would prob see closer to 380rwhp
and im sure yours would beat these apparent stockers making 260rwhp+ on 12psi, dont believe that for a second.
Edited by cactus
260rwhp isn't too much of a stretch.. my 20 with the 25 turbo made 245rwhp on the same dyno and my 30 with the 25 turbo made 243rwhp on the same dyno again, both at 12psi (different days account for the 2hp loss :thumbsup:) my mate has his 33 dyno'd at some place SOR and it made 296rwhp with stock turbo.. THAT is a stretch.. VERY happy dyno there!
i recommend the HKS GT-RS i think brand new from www.greenline.jp is 2.5k give or take...i've been in [Michael]s car and damn its responsive and powerful hahah or even the Trust TD06-25g or 20g but i would go the HKS because its coolant and oil cooled the Trust turbos are only oil cooled also the Garret GT30 series they good to hehe :P
lol thanks :thumbsup:
if you got the cash go for the hks kits as they are bolt on and comes with everything you need or else just get a garret gt30 series turbo(everyone seems to like the 35r)
Edited by [Michael]
Dude i have a GT35R on my FJ20'd DR30 that makes 330rwhp @ 16psi and 355@ 19psi so I opt for the Garret, go to horsepowerinabox.com, they have direct replacement GT series turbo's for Nissan engines for just under the 2k mark.
P.S. The DR will lay SERIOUS rubber down in 3rd :}
I've heard those bolt on GT series use dodgy exhaust housings.. you can get a brand new GT35R for around ~$1800 *paid (1600 for mine but they were special circumstances). A lot of fab. work to be done though.. ;)
Well he either needs to find another tuner (I like Hyperdrive and they do all my tuning, but they said his turbo is maxing out) or look at another setup.
He did ask about other turbos, I was merely pointing out that there are bigger options and that I've heard bad things about the horsepowerinabox turbos that use standard exhaust housings whereas real Garrett items don't.
380, let's not go too far!
But 260hp on 12psi is quite easy for a stock RB25
Are you 100% sure its a hks 2540?
Yeah, check that out first ;)
haha yeah 250 is not too bad, i had a redtop 20 with 25 turbo makin 240rwhp @ 11psi, but 270rwhp @ 12 psi i cant see happening unless its a freak lol
He has an RB25, not RB20 :)
yeah, i would be having doubts its actually a 2540 (given the tune is ok).
if its HKS, it should be marked on the front cover with HKS shouldnt it?
I'd be checking too.
On the top of the shaft, in between the compressor and exhaust sides HKS stamp the model on the little silver label.
:O just had a better look with the torch to find the GARRETT on the turbo, did the 25 come stock with a garret turbo? i shall be visiting the guy who sold it to me now :P ... well its an excuse to get a new turbo anyway
if it has garret written on the front it aint stock because the stock rb25 turbos have nissan (eg:http://www.imagestation.com/picture/sraid218/pdaf6db9e994775671341d8e5f6208cf4/ec08caf8.jpg) so if it was a gt2540 you could easily tell because hks would be written on it somewhere...
tru, well so i have a garrett something, il probly take it in somewhere tomrow to see if they can tell me what it is... F#&KN Pi$$ed off tho, im gonna go see the guy who sold it to me and work something out
