i was on no explode and musashi mass gainer... cos im a skinny bloke ! i stacked on the kilo's with the right eating and blew up like a baloon.... but as soon as i stopped taking the mass gainer and no explode... i lost a sh!t load of size !! so i have taken up Muay thai now... looking to get ripped instead of bulk... wish i was a fat guy though =(
Don't wish you were fat...even though it's easier to gain muscle, fat gym junkies develop bulk muscle and it always looks weird, even with roids and creatine, because they developed it on a fat frame without slimming down first. This can be attributed to poor range of motion due to restrictive size plus muscle having to conform to fat. Starting off with a thin frame usually takes longer to develop the muscle but it looks a heap better in athletic form and given long enough you can get to the same size and strength. No contest, I was the skinniest dweebiest kid in my year level all throughout high school even after peaking in height...I still see everyone from high school and now I have the broadest shoulders of them all! And all the fatties who currently go to the gym still look fat, they just have muscle to go with it too lol.
And when you start naturally filling out you'll be grateful you aren't one of the ones who receives a stomach in front :P
hahaha... i zone out after the first sentence... x.x
well not all martial arts will get you ripped... but muay thai... come on man have you seen some of the training drills you do? its insane and if you can complete every set you will be ripped in no time... i tend to fail and collapse to the floor halfway through however..
getting ripped comes from food.
not muay thai
But you have to have some muscles on you before you can cut down to it.
quickest way to gain muscles?
eat lots of food and do compound movements with heavy weights.
no swiss balls, balanced boards or DB's required
Edited by GTST
I don't get this sudden bodybuilding craze where your torso has to be 3x the size of your waist and legs lol. How do you guys get into this stuff, is it by going to the gym and working out a fitness plan, or just by forums and hanging around like minded people?
every guy wants to be stronger than the next.
it's built in to our code.
not everyone wants to look like Arnie.
but every guy will look in the mirror and think "I wish this or I wish that"
you can't help but want to better something about yourself.
and once you get in to it, it's never ending.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
