I just stick to Dymatize Elite.
Tastes great, easy to get, enough protein in there and so on.
CBS risking buying poor tasting protein in bulk and then being stuck with it.
I'll give you some of mine if you wanna risk it ya girl :D
Define quick lol?
Did you get calcium caseinate or micellar casein? Usually the casein taste extra gunky and like crap.
calcium caseinate
Within a few minutes should be fine...Last night when I had it for the first time I put it in water on it's own first to taste it without adding chocolate WPI...It's drinkable on it's own, flavorless for the most part. I threw a scoop of WPI in after that and drank it straight away.
This morning I mixed it up and put it in the fridge for maybe 15minutes before leaving for work...When I started drinking it I tasted a hard piece and thought it just didn't mix, so I shook it, and noticed white hard pieces settle on the bottom... So yeah, drink it straight after you add the water and it should be fine
Why did you opt for the calcium caseinate over the miceller casein?
Ahh I didn't realise that it is flavourless! I guess i could mix in some Dymatize for flavour.
Not sure to be honest, it's the first time I've ever bought casein and they both seem to be the same reading the description, only the calcium caseinate has a higher protein %
Haha yeah I was trying to work that out myself. I was like the description is the same...yet they are different somehow.
Thanks for the advice, I'll try it out and see how I go.
Nothing worse than chewing on chunks of protein clumped together or sticking in your throat. Shit becomes like chewing gum. Think I'll invest in a blender when I start taking protein again.
Chunks of unmixed powder are one thing, this was solidified chunks, like a plastic texture...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
