While on this topic, has anyone here gotten a friend to push down (encourage the negative phase of the lift) on a bar, etc. while you try to resist? It's like super negatives lol, crazy hypertrophy results
Yep, when bench pressing on a Smith. Was crazy sore afterwards.
Not to detract anything from that monster, but how much TUT do you guys devote to squats? I go much, much slower than this guy...is it more taxing to go faster or slower? I would think the latter, given you don't have the elasticity/spring helping you out on return. I think if I was to go as fast as this guy, I could probably do more weight but would end up with some pretty bad technique. Is there an explosive benefit to doing it this fast?
Sounds good I might try that. Sounds like you'd need really good technique to pull it off safely, I can see how people might do their lower back or pull a leg muscle coming up quick from a parallel or deeper position.
yeah I go a lot slower than that... nice and controlled on the way down and then explode up... the weight will dictate how much speed you have on the way up anyway... as long as you don't 'bounce' at the bottom I think your fine
I just think head/chest up, ass/hips back first (before you break at the knees) and weight on the heels
ps. that guy is about 5'2" and 75kg which makes this even more impressive
Is the guy wearing knee wraps in that vid? can see black but not sure if wraps or just sleeves to keep the heat in.
Anyway, strong muscle is a big muscle is a fast muscle. I don't know all the correlations between TUT and bb and hypertrophy etc, but I do know when you've got big weight on the bar you're not there to f**k spiders.
I think you'll find it's the opposite - the slower you go the harder it is to move the weight because you're not recruiting as many fibres during the lift.
Also, stretch shortening cycle (css) does help out the hole (referred to as "the bounce"), thing is this guy is doing 1/4 squats so not much elastic energy being stored.
Best thing is to experiment with yourself and make your own conclusions :)
That's fairly light, but squats should be easier for short guys or people with short legs?
5'2 is short as hell and squatting would alot easier for his short little legs.. Not like us guys that are over 6 foot.. Takes twice as long to get to the ground lol
Yer, that and I was thinking longer limbs = more torque/leverage working against you when you bend your long legs.
On the topic of protein powders, do you guys drink them on your off/rest days or just on days you do exercise?
I've got some Musashi 92 on hand which is low-carb and take that if I'm in a rush and don't have time or access to protein from a whole food source on non-workout days.
And then keep the protein supps that have more carbs in them for the WO days.
Finally found out my body fat % is:
Currently 82kg at 13%BF. Also started doing deadlifts again today with 120kg x 3 being my best effort. Time to step it up
Fat flamin mongrel.
lol what gym do you go to?
Dude I suggest you do some research before posting...
"When a high dietary protein intake is consumed, there is an increase in urea excretion, which suggests that amino acid oxidation is increased.."
It depends on the types of protein you're consuming, unless you've been consuming a lot of slow-release proteins throughout the day, your overnight release won't last nearly as long as consuming something like casein before bed (4-6 hours release).
... Believe what you want (supplement packaging) but I'll take advice from a guy who has a bachelor and master of science in nutrition and over 18 years experience.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
