Hmmm, might even be best speaking to Terry about this one, I like to think i know a lot about supplements but still nothing in comparison to him. Dont want to lead you down a garden path if im not 100% correct.
All good man, appreciate the insight regardless.
lol fk off Troy ya tub of lard :P
Does anyone ever get headaches / hangover feeling from certain proteins or supplements? My favourite brand of all-in-one supplement has changed something about their mixture (hadn't ordered from them for nearly 2 years) - this one smells kind of fishy and clumps up a bit more than the previous mixture, despite the breakdown label and taste being much the same. In the first week of using it I had some slight headaches on and off, but could just be coincidence, I might have had a bug for that week.
Sounds like a bad batch and you should return it to the store Birds? Did you buy more than one tub (check the other)? If it smells fishy that's no good.
Can't say I've really had headaches from supplements, only sleep deprivation from the caffeine.
This thread is starting to look dead so thought i would add some of my progress...
Recently started a 5x5 program to change it up a bit. The idea being 5s sets of 5 reps so obviulsy heavy. Then try small prigressions in weight for the next session
The key focus for these lifts are 100% technique and full range of motion. This is important so I dont cheat in the rep just so I can say I got all my reps and it's time to up the weight next session.. Upping the weight should really only occur when all reps can be completed without a spot or maybe failing in the last rep of the last set.
I've found this routine to be pretty good, done 4 weeks now so will probably only do another 1-2 weeks before changing it again..
Some examples of progress are
Weighted heaves
Started at 10kg doing 5x5
Last session was 20kg 5x5 with a fail on the last rep of 5th set
Weighted dips
Started at 20kg
Last session was 40kg 5x5
Deadlifts
Started at 140kg 5x5
Last night did 150 5x5 (really should of done 155 I reckon but pussied out)
Barbell lung walks
Started at 50kg 5x5 (5each leg so 10 reps)
Last session 65kg 5x5
Squats would be a good one but I've revised my technique so really I've gone backwards
Edited by GTR_JOEY
What's your weight?
I'm almost there myself; couple kilos off. Granted, I only attempt the 1RM after my 6 sets (OCD thing).
Some might be pleased to know I've relaxed my philosophy on restricting what I lift in order to keep my body weight down and balance the body shape. Have let lats do what they want (haven't stepped these up for 2 years), 5th and 6th sets on pulldown are now 220 pounds instead of 200...another 30 pounds and I've cleared the whole stack teehee.
Might have to look at weighted pull ups then!
Competed at GPC Nationals about a week ago.
Weighed in at 91.4kg
Squat - 190kg
Bench - 110 kg lol
Dead - 220kg
All PBs for a proper 3 lift comp.
As single lifts, the squat was a 5kg pb, bench was 5kg under pb, dead was 2.2kg under pb.
Most importantly I didn't cripple myself.
Next one is end of August. Hopefully bench will improve if I can complete my lifting plan without elbows and shoulders falling apart.
Edited by TTT
decent lifts.
First session back in the gym for a couple weeks. Must say the lack of diet and training for the period has hurt my progress. Was much weaker then before and have noticed it in my appearance.
Not to worry, hopefully wont take me long to get back to where I was and keep on going after that.
What's your weight?
I fire the same question at you Birds, what is your weight?
Currently 80kg @ 6'3
1RM for bench is 115, done after my usual 6 set workout and taken to an inch from my chest. Tried for 120 but failed half way back up...confident I could pull it off with just a warm up and straight into the 1RM!
Can anyone here strict military press their own body weight? That would be impressive
1 rep? In front or behind neck? Doubt I could do my own weight behind neck, but again, it's an exercise I've left dorment with regard to stepping up. Might start increasing it now that I'm doing that with every other exercise.
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
