I bet some idiot has tried that before haha!
I've seen someone doing standing skullcrushers on the smith :unsure:
I do tricep kickbacks on the Smith machine.
Definition required :P
Only thing I ever really use the smith machine for now is shrugs on the odd occasion, usually when the olympic bars are in use/demand.
yeah i didnt like it either, but had to be done. The alternative was to leave without squating or wait 20 minutes for it.
funny thing, because my current routine jumps around the body for push pull, earlier in the routine I did standing military with the Olympic bar. Don't know why but it felt so much better then using just a normal barbell.
Oh no FIGJAM you got a disapproval from TTT - quick make a witty comment about squats again :laugh:
on the spot now i'll have to make it a good one
maybe squats can help?
that was a bit weak....
And already being hazed...
i'm cool with that, only been at the gym for ~2 months so my knowledge and/or experience is limited to say the least. hey practically the same time i've been on SAU!
Squats will help with strength bro
HAHHAHAHAHAA
Edited by darksky34
nobody would let you work in with them?
I don't know why people don't like working in with squats or deads... the time between sets is more than enough for someone else to reload the bar and get a set in
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is 2050 rpm, going to WOT sees the MAP go +ve very quickly and it has >5 psi by the time it hits 90 km/h. That's still <2.5k rpm, so I think it's actually doing really well. (I edited this from a previous version where I stated 80km/h was <2000, but that was a false memory. If I am rolling at ~1700 in 5th and floor it, it will start making boost before it goes over 2k - which is a separate "experiment" leading to the same conclusion. Which is that the boost threshold is actually quite low. It's not fast there, obviously, but it certainly makes progress towards going fast, which is not what it's been like for a long while!!) Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
