4 scoops BN chocolate micellar casein
3 LARGE tablespoons Jalna low fat vanilla yoghurt
Skim milk until desired consistency reached
Tastes somewhere between your usual chocolate mouse and chocolate cake mix...so f**king good. It's in the freezer now though, see what it's like frozen.
I got halfway through it before I felt sick, so while the taste isn't super strong it's definitely a bit much for me to stomach heaps of haha. good thing too, it's undoubtedly somewhere near 600cal hahahahaha
Whaaaat? Only 600cal?
Doth thou have ye olde testicles?
Well the idea occurred to me as a replacement for desert for those who can't deal with their sweet tooth cravings (not myself)...so having a caloric value the same as a normal large meal isn't ideal :P
Your gut sounds soft.... I'd put it on a strict diet of squats to harden it the f**k up
I already squat lots :( but I agree lol
f**k YEAH
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
