All I hear is whinging about techniques and width of equipment. At least you can move both your arms and do the friggen exercise. If I could do dips between two shopping trolleys with a couple of retards holding them in place I would.
angry_birds___red___super_high_quality__
yes and yes
an olympic bar is 7', 20kg, bearing collars and takes olympic plates (the big hole ones)
standard bar is the stuff you have.
they also make an olympic ladies bar which is 6' and 15kg. the collars are shorter and the gap between the collars is the same as the 7' ones.
just incase you want the lady version.
Sell your shit on ebay, add some more money to your funds and get a cage/bar and plates package like this..
http://www.cyber-market.com.au/cyberfit-power-rack-100kg-olympic-weight-flat-bench-p-591.html
More than you'll need for a while.. and you can always buy more plates as needed.
or if you want to retain your plates you could get something like this..
http://www.gymdirect.com.au/item/5-Package-Deal-_-BPR02-Power-Rack-with-high-low-pulley--+-FD3-flat-bench-+-100kg-barbell-dumbell-set-$865/109.htm
Just trying to follow your logic on buying an entire kit if there's an option to just buy a longer standard bar. Doesn't seem like there is any unless the goal is to ultimately move to Olympic gear.
So I have a new attitude towards this shoulder injury. I thought f**k it...I'm gonna come out the other side of this thing with a positive: huge f**k off legs. Time to make up for the years of neglecting legs in favour of upper body.
So until the physio gives me the all clear on upper body movements, I'm gonna smash the shit out of legs 3-4 times a week. This will involve:
Squats
Squats
Leg press
Hamstring curls
Calf raises
Possibly more squats
Legs progress shot from me.
Congratulations dude, you're my motivation to put some serious size on my legs over the next 8 weeks or so.
Exactly!!!
I can't do chest so have trained legs twice this week. Tonight was shoulders and traps but before that did 10mins on the bike as warm up and then 5 sets of squats.
Want my legs to get heaps bigger and stronger in the next month.
Fark that session felt good. Hamstring curl smashed my hamstrings in a way that deadlifts can't. And it'll be good to balance out legs with some calf work for aesthetics :)
Satisfaction at the end almost makes up for no upper body work during the session. More energy for squats too, which I normally save for the end of the session.
Sounds good Birds. Hope it all goes well for you mate. An old PT mate of mine stuffed a tendon in his wrist (forget the exact injury but basically sheared off the bone I believe) but it was depressing the number of exercises that ruled out. He found ways to use wraps or particular machines to work around it as much as possible until it healed up completely
With legs being such a big muscle group too I think it should help burn the calories up
I've always had decent upper legs, they would be my best body part. Have never had to do too much to them to maintain volume and they respond well for me. Whereas back , shoulders etc I seem to need to work continually to maintain any size. I'm going to focus on the calves a lot more and hope for some sort of development there. apparently for some people it doesn't seem to matter what you do they just wont respond.
Advice/help from those in the know please.
I have a fairly noticeable size difference between legs due to an old knee injury and would like some guidance as to how to even them up. I have full range of movement but the injured knee isn't as stable as my good knee.
My lower body workout currently consist of the following once a week: Walking lunges, Squats (parallel), Deadlifts, Hamstring curls, calf raises, single leg dead lifts and jumping squats.
Try to do cardio twice a week, HIIT resistance circuit, HIIT on rowing machine/stationary cycle, if I have time XC mountain biking. Also do two upper body days a week, a three day split works best for me so I can keep workouts short after a long day at work. No training Sunday/Monday.
Some people tell me to do single leg exercises and do more reps for the weak leg, others say start with weak leg and only do the same amount of reps for both sides. Other people insist I should keep doing what I’m already doing and just concentrate on driving with the weaker leg more.
I train for general health and to blow off steam after a 13+ hr shifts.
I do need to have a reco at some point but time, money and rehab process put me off the idea while it mostly works ok.
If anyone can help me out that would be great as it's really starting to shit me.
EDIT: I just worked it out MORE SQUATS!
Edited by numleg
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
