Yeah gonna suffer DOMS hard, but should be worth it. If I find the load too taxing I'll cut down. I just wanna exercise as much as I can to make up for lack of upper body movements. Need to keep the calories off.
I don't think you need to worry about this, especially next week.
If you injured yourself badly I'd be reluctant to lean on it without at least giving it a weeks rest.
Better yet, see your chosen therapist and see what they say.
Seems like you're busy enough squatting anyway :)
Tried an empty bench bar in the same session and it didn't present any pain...I could be back to upper body sooner than I thought :)
Playing it safe though. Do we think it's worth doing movements like bench with an empty bar for rehab? Or just wait until completely healed and get back into the weights?
Feeling pain or not, isn't a good indicator with the rotator for recovery. The pain is there when the swelling goes up and that can take a few minutes to an hour before you start hurting. Hence your bench blew it out but, you didn't feel it till later on a relatively light excersise. You can have deterioration in the muscle without feeling it as pain, so be carefull.
testing very carefully the 'weakness' is the way to go. You want the strength to be at least that of the unijured side.
Bench press isn't a rehab movement for this injury. Don't bother with it. Even the empty bar bench doesn't address anything related and you just look like a feeb doing it.
Copy/paste from my build thread as questions get answered quicker in here.
For some reason, my back is worse than it's been so I either did something Friday night or sleeping in shit hospital chairs/not sleeping is giving me grief (Kate has been in pre-labour for the last 3 days so we've been in and out and not sleeping very much). No gym on Monday as a result so I've had a good 3-4 days off.
Not even a stretch is helping me and it's pinching randomly when I'm not doing much.
I've noticed, with squats, that if I go below parallel my body tends to lean forward at the bottom of the motion which I'm wondering if that's causing some kind of cantilever effect on my lower back as I come back up. Or is some form of forward tilt at the bottom of the motion normal/acceptable?
Extra info: A podiatrist friend came over on sunday and did some tests, said my legs are 1.5cm different lengths, specifically from the waist down so nothing from the back as she measured that too. I put orthotics back in my shoes (just off the shelf ones) on her advice on Sunday but I "think" my back was already playing up before that.
Edited by ActionDan
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
