too hard to get enough protein from food (and having to watch calories) as well.
wut
Chicken, tuna, kangaroo, egg whites (cooked). There, those are the leanest protein sources I can think of off the top of my head. Their entire calorie content should pretty much be from protein, as there's really next to no fat.
I could easily blow out 300g of protein in a day without touching a shake/supp.
Dunno, but I had it straight from a pig's leg the other day so I'd like to see em tell me it was processed!
Not that I give too many f**ks for processed or unprocessed foods.
I think the ham you buy from the deli in Woollies etc is probably semi processed, not that I can see it as a bad thing as long as nothing is added to it.
Only concerns I have with processed meat are unnecessary additives (salt, sugar, etc), and not really knowing what part of the animal (or God forbid, what animal at all) you're eating. lol.
Meh, as long as the protein content on he back is high and the fats are low, I don't care too much. Processed food does tend to have a higher fat or sodium content though.
That being said most of the stuff I eat is fairly organic, just cause it's what I like the taste of.
You mean you like the placebo effect of organic ;)
Trozzle: I eat all of the above usually once a day apart from the eggs. Can of tuna for morning smoko, chicken breast for lunch, usually kangaroo or lean beef/steak for dinner, still not the 1g/lb that I'm trying to reach though, and I don't want to / can't eat more meat than I already do.
The 24-5 g from a shake a day helps things without heaps of calories, and I quite like them for a drink after a workout!
That prolly came out wrong, I don't like the taste because it's organic; I like the taste and it just happens to be organic.
I love my processed foods and fast food. Just don't eat as much of it (once a week etc.) cause I tend to avoid high fats.
wuuuuuuuuuuuuuuuuuuut. No really, wtf lol. I can't fathom this, do you only eat like a mouthful or something? See below for me today.
Here are really nice and most informative post. I am totally agree with you all. But according to me other cardio exercise are better then join a gym. And Supplements, I think that it's not essential to build up your body and if you used it then after sometime you can see side effects of it. So try to avoid such things.
Am totally agree with you friend. Supplements is filth of manufacture processes, and after used for period of time side effects is happening. I avoid such things as to function brain better.
Come to my class for a grammar lesson please, kthanxbai
a very rough calculation of my daily protein intake is
15g from tuna
81g from chicken breast
30-80 depending on what I eat for dinner
24g from whey powder
plus a small amount from my morning oats with a splash of milk. Assuming I'm eating a decent amount of meat for dinner, that brings me to around 200g, which is my 1g /lb of lean body mass.
I was eating cottage cheese / greek yogurt for dessert for a while, but I've been trying to keep my calories down.
On an unrelated note, managed to get bench, OHP, deadlift and squats in today, was quite pleased!
Edited by bozodos
haha not confident enough to do that Birds. I'm glad I started before I started getting serious man tits or fatty legs though.
Getting a bit sick of people trying to tell me I should be going to MMA / Kickboxing / cardio classes instead of lifting because "lifting won't make you fit or lose fat" (apparently the 15kg I've already shed is just water weight). Funny how they're the ones whose body composition doesn't appear to change, apart from the ability to run for kilometers on end.
It does motivate me to keep going hard to prove them wrong though, but I've recently started running/jogging as well to try and kick things along a bit.
Heard a couple of chicks at the gym the other day talking about how often they want to come to the gym; saying they don't want to come more than 3 times a week because they didn't want to end up like those bodybuilding women...
headisfulloff**k.tiff
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
