I was trying to go ATG as in calves touching hammys, basically as low as I can go, I find that easier than stopping half way down or a bit below parralell which feels like it would be a heap of pressure on the knees.
Not yet, considering it though. Current physio has me doing nerve glide/mobility exercises but after paying close attention during stretching etc I feel as though it's coming from the lower back.
been to a chiropractor?
my little brother had a back issue when he was younger, turned out his hip was out of place slightly resulting in one leg being longer then the other.
My legs are out by around 3cm every time I get trigger point :(
as low as you can go and as low as you can go with correct technique differ vastly. going ATG and compromising form isn't a good thing.
Even though you stretch etc. daily, do you feel you're making any significant progress? Maybe you need to review what you're doing if it isn't effective?
Buy starting strength or something that explains technique in depth, that way you can refer to it whenever you're in doubt to coach yourself.
I'm not sure if this will answer your question Dan, but I think these videos are worth a watch anyway. I watched them last night as I'm having an issue with my knee bending in during squats. It's a five part series called 'So you think you can squat' Here's a link to the first one
Easier to just go and see Matt again. All I need to know is if the butt should be rounding in under/tucking under naturally or whether that should be avoided.
I reckon that's a good idea.
I dont think It's natural to the squat, you're not squatting any lower, you're just pushing your arse down. That's my guess. I'll let someone in the know answer.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
