Birds as per your post in Leesh's build:
You mentioned that you don't believe that if you tried your 1RM before starting volume training that you wouldnt hit the same volume as if you did it the other way around due to muscles getting sore.
Yet you went on to say that 1RM at the end of your set can be in your opinion a testament to true strength (along these lines), but as per the above, if you are already stuffed from volume training then surely your 1 rep max weight is less then if you performed it just after a couple light warm ups.
I know you aren't after 1RMs or sole strength gains, but can you see how what you said doesn't make absolute sense? You contradicted yourself in basically the very next paragraph. Or did I miss something?
Hope that makes sense
Due to muscles tiring*
No I didn't say anything about it being a testament to true strength. All I said was, if you can do a 1RM after your volume training, you can do it at any time on and given day, even if you feel sick, when you haven't had the volume training to tire you out first. Of course I believe your 1RM will be higher before volume training.
Rather than contradicting myself, I was actually pointing out the contradiction that you thought I had made: people say that volume is completely unaffected by doing 1RM prior to it, but that 1RM is affected by volume prior to it. I argue that you can't have one and not the other.
sorry mate, misread the paragraph.
I agree with your point.
If you have been busting your balls every workout and then change the workout to go for a 1RM at the beginning rather then at the end, then something has got to give.
If you do a 1rm at the beginning of the workout and push out an extra 10,20,30kg (whatever) and then hit the same volume levels in the same set and rep scheme (or even improve it) then something is drastically wrong.
My opinion though.
Yep that's true.
And before anyone jumps in (because I always have to disclaimer anything I say in here), I'm not saying that doing 1RM at the end of your volume training is the best way to increase your strength. The traditional method is to do your heavy singles after a warm up and then follow up with your volume training .
really depends on your end goal.
Trent @ PTC told me to do 1RM's every 3 months just to see where I am at strength wise
as an indication not a definitive this is the be all and end all or to get stronger, just as an indicator
Edited by -FIGJAM-
Good article; it says an elongated version of what I say on here every few weeks or so when I get sick of reading the unnecessarily pedantic questions about the 99% or someone's latest idea to achieve the 1% when they haven't even got the 99 yet.
Actually on second read I notice no mention of steroids, yet being IFBB and looking at the dude it's hard to believe he wouldn't be using; not that I don't agree with all he's written, but it's kind of interesting to see no mention of it with regards to training and recovery etc.
I like the part where he says Troy should be eating complex carbs like pasta and bread :P
Since when was bread a complex carb (in most cases, given white bread is most popular)? I thought it was a shitty carb lol....either way, I do eat carbs. Far too much lately.
Interesting to be is the part about push/pull/legs.
I've always done full bodies 3x weekly (well not lately but usually) but I've contemplated if I'd be better splitting like that.
For anyone else who does that sort of split, what sort of exercises are you doing to fill an hour?
Before leg and back issues I was doing, squat, bench, DL, bent rows, weighted chins, weighted dips in that order.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
