I'm slowly thinning on top, must be the governments fault.
Ain't nothin' slow about my thinning Yo.
This is a story all about how my life got flipped, turned upside down And I'd like to take a minute just sit right there, I'll tell you how I became the prince of a town called No-Hair
had a guy notice me doing cuban press, face pulls etc yesterday, gave me some good pointers with other prehab type exercises I could do (turned out to be a doctor).
Birds that sounds like something the pro BB in our gym would inflict onto one of his PT clients, except for the fact that he dosen't squat so it would be leg press and calf raises lol. how long did it take you to recover afterwards?
Not long til I could stand again, but my legs were cactus for the rest of the night. Dropped down from the pull-up bar and my legs had trouble standing back up etc.
I guess where this shit gets you bad, is that when you are squatting a big weight, your leg and back muscles will go until they can no longer push up another rep of that big weight - but that doesn't mean they don't have lots of strength left in them - just not enough for xxxkg. Hence you can stand easily afterwards under just your own weight. Drop it down to something light, like 60kg, and your last rep at this weight is more likely to drain you of any remaining strength, to the point where you can't support your own body weight for a minute or two. I imagine body squats with no bar would do you even worse.
Give it a shot sometime, after your heavy weights!
I used to think I could do that with 40kg, was trying to prove a point... got to 30 reps lol
Funny this, I don't remember you conceding your point to me; seemed to forget all about it :P
I really have no idea - the most I've done is 64 reps of bodyweight in the 8x8 setup for Tabata!
I tried it again lastnight with sets of 90kg. Back hates me today. Did better in squats lastnight than normally, so I'd say the huge set of 60kg helped somewhat.
Probably :)
But we know I'm too stubborn for that...and my old pb was based on a 1RM after working sets,
However I have switched my squats to that style (1RM before working sets), as they were actually on a severe plateau that I couldn't break through with any other way.
Probably :)
Birds, stubborn?
:whistling:
  • Like 1
Stubborn Birds got a 115 bench tonight, so another 5kg and we are home for a new pb :)
Though thinking about it I never used to touch chest; it was always within an inch of it, so I'm probably actually stronger than I used to be.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
