Have tried BN WPC chocolate, choc mint, mocha, banana. Chocolate is by far the best, banana is nice but very sweet, choc mint and mocha are average.
Have tried BN WPI chocolate, coffee and vanilla. Chocolate and coffee are nice and vanilla has no flavour to me really
Edited by Dani Boi
Do yourself a favour and do not try piña colada flavour, ugh
I think WPC has less or very little lactose in it, couple people I know have felt sick after consuming compared to WPI.
But yes WPI is more highly refined it's like skim milk versus full cream. Less fat but at what cost, the former is basically water. You get *slightly* more protein per gram from WPI, but if you're not lactose intolerant, WPC is probably more derivative of actual whey than WPI.
In short, I have no clue, but someone might know.
Assuming the lactose thing is accurate, the only logical justifications for buying WPI over WPC would be taste...and if you think that taste is worth paying 50% more (give or take) then by all means be my guest and throw your money away lol
People always say that, but if it is something that is consumed more often than not, why not enjoy it?
I'd prefer to pay $10 more a kg for eye fillet than blade steak.
For those people, I wholeheartedly side with Markos (and perhaps Tolga? Idk) that they're pissing their money down the drain relying FAR too heavily on supps. If you're consuming something in enough volume that the taste becomes a concern, I believe that would mean cost is of even greater concern due to increased turnover.
Creatine, krill oil and wpc are the only things I have.
Most of the time I forget to have the creatine.
I've given up on powerlifting due to too much time injured and yet still weak (comparatively).
Now lift what I want, how I want and am enjoying it more.
Currently eating a "winter diet" lol.
Going to do a 12-16 week cut closer to spring.
I did some curls, and I liked it... Hope my powerlifting friends don't mind it.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
