I've never understood this.
The sensation of having your dick sucked would well and truly be overruled by the sensation of having a dick in your mouth.
Nothing wrong with having your own dick in your mouth, otherwise jerking off would be the equivalent of giving another guy a wristie.
Why not, it's just another body part achieving the same thing
Dogs and other flexible animals do it. Trust me, if we were born with the flexibility to do it, most guys would
To help with your logic
Jerk off = your hand on your dick
Blow off = your mouth on your dick
Homo wristie = your hand on another guy's dick
Homo blow job = your mouth on another guy's dick
To connect one you would have to connect them all, either making every jerk off session gay or every self administered blow job completely straight
God no lol
I'd much rather wait and get the good stuff, but man can only wait so long.
That's a different discussion though. Doesn't change that I don't want dicks in my mouth, including my own.
  • Like 1
I don't get why someone would need to jerk off once they are in a relationship where they see their partner every day, unless their partner is shit and doesn't meet their needs. Sex should be at least daily why jerk off?
Edited by L33SH
I thought I was in the wrong section for a minute, did I hit some wasteland thread?
On topic, I said I was going to post this ages ago but forgot, might get the topic back on growth chamber talk.
Copy_of_pyramid-weight-lifting-chart.xls
Daily lol, I don't have the energy for anything daily lol
Talk to me in 10yrs when you both work full time and have kids.
Most of us start out with sex drives like that, but for many it doesn't last.
Nothing to do with my partner, everything to do with time and energy.
LOL, young adults and their sexy time.
Get some life time up.
I remember living with new born babies, quite some years ago now, but back then we would rather sneak off and sleep, actually back then sleep was better that sex.
Stupid babies, they are the devil incarnate.
EDIT: Stupid kids, they are the devil incarnate.
Mine are 13, 14 and 15.
You are going through the terrible two's I take it, that's like a f**king holiday, wait for them to get to teenagers, mine are breaking my balls.
They are good kids mostly, the boy is easy to deal with, the girls, well they are another story altogether, teenage hormones going insane, boys and shit hanging around.
This is my punishment for being a shit kid myself.
This is also why I need to smash weights 5 days a week, keeps me keep calm at home.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
