Well, after a couple of months of sweating the ID inspection, I got the 34 with NSW plates through Sturt Police today.
I thought that it would be referred to Regency for further inspection but it didn't happen. One of the boxes on the inspection sheet asks if further inspection is necessary but he ticked the 'NO' box......whew. :thumbsup:
Obviously coilovers, lowered slightly, airpods, wheelspacers, Kakimoto Dual N1 exhaust & BBS wheels with 265 rubber are all OK as long as they're within spec and all mounted well.
Now I can finally bolt on all the stuff that I've been acumulating for a few months.
good to hear :thumbsup:
Thanks Cara
hey congrats man!
post up some pics with the new goodies??
Thanks, I'll try.........but its things like bigger garrett turbos, cams, power fc, hks elec boost controller, injectors, fuel pump rail & reg, bigger tube & fin fmic, different air pods, improve existing exhaust with split dump pipes etc, better clutch and a few other hidden things.
Most of that stuff you don't realy see unfortuantely.
what garret turbos u thinking?
Wanted to stay low mount so I've already bought a pair of GT2860R 707160 -5.
No point in going top mounts or big single unless it sees the track or drag strip more than the street.
Not wasting any time are you? 350-400rwkW here we come.
*cough* and some 32s * cough*
*cough* and some stageas *cough*...lol ;)
Seriously though, the 2860rs -5 are basically the same size as the standard turbos from the research ive done recently, just with steel wheels.
Ive just fitted the 2860rs-7 to my 260rs, which in my case was the biggest i could go and keep them low mount cos theres not alot of room under there! The next up from there is either a -9 or -10 which the exhaust housings were too large to be mounted, but also they dont come on boost til very late either so it doesnt make it very streetable as a daily.
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :(
*cough* and some stageas *cough*...lol >_<
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :P
i think you got the sizes mixed up
2860-5 (2530's) isnt same size as the standard turbos, and -5 is bigger than -7
Had me worried there for a minute :) . Just did some research and found the standard turbos have a .53 housing (actually stamped on the turbos) where the -5 has a .60 & .64 respectively. The -10 has a .64 with an optional .86 housing (too laggy for street and too narrow power band).
Also found out something interesting.....all new GT28 housings out of Garrett now are stamped 2560R but specs are still the same as 2860R....this straight from their website:
For those familiar with our product range, this means that the unit formerly known as "the GT28R" (part number 466541-1) is now in the GT25R family. More specifically, it is now a GT2560R model.
Wow, I can't believe it got through with wheel spacers - it really was your lucky day.
Sounds like your plans are for a nice tough real streetable GTR.
Surprised me thats for sure......probably because the wheels are just inside the guards that he didn't look or care about it.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
