Hi,
Im still looking for an R32 Gtst 5speed must have sunroof, prefer white or blue, and gtr bar if possible. Must be good condition with RWC. Some mods ok but not too heavy as insurance will kill me. Im in melbourne but will consider other states if car is right.
Please pm me or better email [email protected]
Thanks,
Rhett
https://www.sau.com.au/forums/topic/20097-wtb-r32-gtst/
i have a sweet white r32 but in qld and a bit outa ur price range but i may be able to fix that by taking mods off it which will also help insurance issue aswell..... its for sale in the cars for sale section may be a few pages back.....
https://www.sau.com.au/forums/topic/20097-wtb-r32-gtst/#findComment-421870
  • 4 weeks later...
  • 1 year later...
I live in Melbourne and I have an R32 93 model. It is blue. It is manual. It has done 85000 ks. It has 18 inch (custom white) rims, near new wet weather tyres, cyclops immobiliser connected to central locking, keyless entry, MP3 player, immaculate condition. Recent tuneup including cleaned fuel injectors, new fuel filter and fuel gauge. legal ride height, still have spare wheel. Brakes, transmission and clutch are in top nick. The car has absolutely no troubles and great on fuel cause it is a non turbo and no sunroof.
https://www.sau.com.au/forums/topic/20097-wtb-r32-gtst/#findComment-1106234
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
