Hi Guys,
I think the subject says it all but does anybody know where to get new rocker cover gaskets for a RB25det engine other than Nissan themselves? I rang Brighton Nissan today as I've been dealing with the guy there for years and he really looks after me price wise... well I hope he has, and he said that I'll be looking at $30.00 per side, there's actually 2, one for each cam but what I forgot to ask him was how much for the bolt seals coz they will also need replacing... no doubt.
I'm not to sure if the gaskets will come with the bolt seals but I'm guessing not... not 100% sure though meaning that there's about 20 odd bolt seals probably worth $3- $4 dollars each? it starts getting a little expensive! What do you guys think?
Does anyone know where to get new ones any cheaper with the bolt seals? Hope I don't sound like to much of a tight ass!
Thanks,
Gianni
https://www.sau.com.au/forums/topic/20106-common-r33-rocker-cover-gasket-leak/
  • 1 month later...
I don't think $33 is too bad. Mine aren't leaking at all, so I would think generally speaking they last around 8 years or more. That beats the hell out of Commodore gaskets which are about $10 but leak straight out of the packet :D
I paid $26ea from Unley Nissan here in SA. I re-used the original bolt seals, no prob's so far.... if you ignore the fact that No:1 ringland cracked :D unrelated of course.
Make sure it is leaking before you go to the trouble of replacing them...
Quite common to spill oil down the intake side when topping the oil up and over time the spilt oil will progress towards the rear of the motor looking just like a leaky intake cam cover gasket...
Clean the oil off with a rag and some degreaser and see if the leak comes back... Mine didn't...
If it's the exhaust side though, probably rooted gasket...
Just my opinion tho...
  • 3 years later...
Anyone know what the part numbers are? Also, would the washer be important. I cant find a dealer where i live that has the washers in stock. they've got the belts though.
I'd be keen on the part numbers as well, my r33 started to leak a bit if i dont let the car warm up...can this be done easily at home?? just unscrew the bolts for the rocker covers and replace the seals etc??
my rocker covers are leaking aswell "aparently" the other workshop i was at changed them... cops ass!!!
how much for gen nissan rocker cover gaskets, i also need a gen nissan exhaust manifold gasket..
therepost-17300-1160253786.jpg you go
Those aren't the part numbers you need....the Nissan parts guy will probably just stare blankly at you. It's much better to have the full VIN of the car but here's what to do:
- double click on the empty box to the right of the one that says 'Part No'
- enter the first three numbers of the 'Part Code' shown in your list....in this case 132....and hit return
- FAST may throw up another box asking which model/year for the car (but rocker cover gaskets are pretty common across the range so perhaps not). If it does you'll have to select (click on) the relevent car/year line in the pop-up.
- the full PN's should now appear in the main window, along with some other info.
Hope that helps
Called Nissan Today:
Rocket Cover Gaskets..
Part No. 13270-58S01 (1x Each)
Part No. 13270-58S11 (1x Each)
Washers (Rubber)
Part No. 13268-58S01 (1x Set of 20 Seals)
Hope this helps. Rob
Screen dump for you :thumbsup:
Oh and the price was about $30 bucks or so think it was $36 but under $40 each. They should have them for me by the next day :thumbsup: also found the part number for the rubber seals it comes in a set of 20 which will set you back about $2.45 each a full set is about $49.50/
Is there much to replacing them??? just unscrew the rocket covers and replace the seals?? obviously in a clean environment so no contaminants get in.
Cheers Rob
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
