Love your work! I think I like the Red with Work Meisters the best :D
its nice but not as stealth bomberage as the blacker.
thats the new batmobile! Id like to see Michael Keaton driving that.
Edited by m3gtr
https://www.sau.com.au/forums/topic/201121-black-on-black/#findComment-3576722
you know I've never been a big fan of black on black but this is about the only black car that has the "love at first sight" effect
Red is hot too, although the CE28 doesn't go well with the white R35 even though it was damn sexy on the 34
https://www.sau.com.au/forums/topic/201121-black-on-black/#findComment-3577057
