Currently Im running a dual diafram clutchnet PP with 6puc sprung disk and a fidanza ally flywheel, thing shudders A LOT, its not a very nice formualtion they used for the disk pad's. For now it has been ok, land up with a very sore left foot and battle to pull away in the wet or up my driveway without chriping the tires.
I am not looking towards somthing with lighter clutch pedal effort, and slightly more HP capability to suit the new motor with around 400kw, Been looking at some twin plate's and from previous experience with the old school twin plates it leaves me with a sour taste, is there anything on the market you guys use that is not to brutal with shudder and clutch load yet can hold some decent power? Did a search but couldnt find anything useful.
The car is used on the street with very ocasional track usage, and the odd drag with fairly small M/T ET streets
Thanks
Thanks
tripple plate OS giken is the g-o, tuff as nails and they dont shudder
What is the pedal weight like? I need somthing that wont kill me in a little bit of traffic, I nengun dont sell them, any idea who does or rough price idea?
Take a look at the Nismo Super Coppermix twin plate, i haven't personally used it but from what i hear its very similar to a standard organic clutch in terms of drive ability around town and is rated for 600hp.
http://www.nengun.com/nismo/super-coppermi...in-plate-clutch
ATS carbon twin plate
is the stuff factory pedal soft just no slip
They are a touch out of my budget unfortunatly,
Looks like a toss up between the Nismo supercoppermix twin and the ORC 709, has anyone got first hand experience with the orc 709?
Contact jim berry in Bris. He made me an organic clutch for my gtr. done heaps of launches and a couple of sprint meets & hasnt let me down. easy to use in traffic & light under foot, doesnt shudder either.
People go overboard with expensive twin, triple & button clutches but it isnt required or practical for most applications.
It only cost me about $350 too.
iv got a orc 2win plate button, its light under the foot, a lil noisy when u step on it, but takes a long time to get use to and not the best on hils or ups n downs or TRAFIC. in fact its real bitch to park in tight spots but u get use to it how ever i always avoid trafic even if it means ill just sit n have a drink till 6 .. not worth the head ache..
might try the nismos next to see..
  • 1 year later...
I had huge problems in my old 33. Went through 2 exedy's under wty then gave up. My old man who is a mechanic got me onto somebody in lismore he has known for 30+ years that did an awesome job on a nice single for me. Held my 345rwkw no problems no matter how i drove it :)
Have a chat to Dave Write on 0266216495. Best thing i ever done. Cheap, quick and he said he builds a few big hp skyline clutches for a few workshops in sydney
Edited by coaster
I'm using an NPC single to hold around the horsepower you are looking to make. Pedal weight is as light if not lighter than stock. Its a bit sudden but quite easy to control once you learn it.
Kills the berry single I had prior to this. Berry clutch was just as grabby but way heavier pedal and with less clamping pressure than the NPC.
been more than 18 months now since I went with the Nismo supercopper mix twin plate, best clutch I have ever used! and as with all things car I landed up with 150kw more than antisipated in the power department... The Nismo clutch feels no pain when the T04z is at full tilt.
I stripped it out last week to change the N1 oil pump, clutch after 20 000km's of abuse still looks like new. Still running as smooth as stock and the only con is a tiny little bit heavier than stock clutch, probably within 10%.
Sounds to me like you've answered your own question. :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
