I think i might be able to bring chairs though they have been in the garage for a while.
Thanks for the Turbotech Jeff, after pulling over 6 times its sitting on 15psi,enough to break traction in second :D
  • Replies 607
Posted Images
bringing boost :ninja: and have a nice big esky for us to fill. think i will bring one chair, as we seem to have a lot of people who want to bring chairs. c you all tomoro ill be there early probably
EDIT: TONGS!! SOMEONE BRING TONGS
<and maybe a bbq>
Hey Guys,
I've got to pull out of tomorrow's event...
My engine started playing up tongiht on the way home so I don't want to take any chances.
I'll see how it runs in the morning - if its okay ill be there!
but for now ill have to give it a miss.
Happy bday Jeff!! hope you have a good one mate.
and hope you all have a good day!!
cheers
thanks shane! you know we can probably tell you whats wrong tho :huh: hope its nothing serious there are lots of little things that can make cars run crap.
im still going, see you all soon. bringing the big man esky
Thanks for everyone that came was another awesome meet :( and was even more special cause we got to celebrate Jeffs birthday!! :D That cake was sooooo good too..
Shellharbour was a great place for a bbq and will be good to use that reserve/beach again! Whoever suggested it (Joeyz/Polak :) )...WELL DONE :(
Hope everyone had a good day I know we did!
Hope all you guys can make it to the next meet in March..
P.s Looking at go-karts for March meet suggested by Joeyz...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
