Looks like it was a great day.
It was a fantastic day... You don't know what you missed out on.
Did anyone get any photos of the pit girls? Or were you all too mesmerised by those skimpy outfits?
  • Replies 237
I can't read the white board and there looks like some people hadn't run.
Could someone type the results out with everyone included.
couple of late scratchings, and the pic wasn't taken at the end of the day, I think Donnan has a list of the final figures.
Top day guys, I thoroughly enjoyed it. Glen and Daniel did a great job running up the cars. Thanks to all who organised it and for having me along. :(
Hi Max, It was good to meet you. That engine bay looks tops. Welcome to the forum :(
Sorry guys, my name was down for the day but unfortunatly i was unable to go at the last minute.
Looks like that day was a success. Big KW numbers aswell.
same, (late) apologies for not showing, found out late on fri that had to work a full day on sat and couldnt get on here to pull out earlier
looks like it was a great day tho! Good stuff guys!
Once again, thank you very much to all those who attended, organised, took photos, made jokes, cooked and anyone who generally made the day a success!
Obviously the day went so well because of the work of Cejay and the boys at ESP, so they should receive the loudest cheers.
Anyways, without any further procrastination here are the results:
(if there is anyone who does not want their results up here, just PM me and i'll take you off)
31:
WhiteRB25DET 153
32GTS-T:
Bullet32 236
Ladybytes 152
ZCR 142
33GTS-T:
33Sedan 165
Tarmac 179
Towlie 164
Trident 292
32GTS-4:
CeJay 162
32GTR:
Donnan 238
Stunnd 214
Phatass 657crazy!
33GTR:
GZR33 421
Misc:
Nick's VL Turbo 286
Mad Max's F6 Typhoon 416
John's MkII Tourer 197
Nico's Supra 320
But none of these could stand the mighty power of Pat's Starlet of mass destruction with it's truly world defeating 54 front wheel kilowatts!
Hi Max, It was good to meet you. That engine bay looks tops. Welcome to the forum :domokun:
Thanks Tarmac. There were plenty of nice cars at the dyno day, and a bunch of nice people to go with it. As you can tell I'm a bit of a Skyline fan, so I'll certainly be checking out the forum from now on to see what other events are on. Cheers, Max.
HAHAHAHAHAHAHAHAHAHA...... :laughing-smiley-014: HAHAHAHA.... :D:P
Cheers for the laughs Donnan
Nice power too Max, pity I arrived too late to see your run. Phatass was awesome, and I really liked the way GZR33 spooled up, sounded very tough.
Sorry bout the late comment was waiting for the power figures etc then I was away working, just got back.
Will hopefully have my engine in and run in by the next event/dyno day. It was a good turn out and the weather was great all the cars there looked pretty good.
I rocked up a bit late that morining (Frikin' got called into work for a bit). Spewin' i missed the Phatass run on the dyno must have sounded wicked? Is there any video footage of the day?
  • 2 months later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
