  • Replies 94
Posted Images
What engine mounts do you use?
Tell me please all your specs!!
Do you have any fotos of your project?
Here is a vid of the car when it had 450whp, and best 1/8 et at this hp level was 7.023 seconds
I have customed engine mounts, but you can buy a set from Mckiney Motor Sports
Presently I have the following mods:
Stock internals RB26
Stock head gasket
Tomie 260 pon cams
Garrett T04Z turbo with 70ar back housing
AEM stand alone with wide band O2
AEM 3.5 bar map sensor
48mm waste gate (cheap ebay)
83lbs seimens injectors
dual 255 walbro pumps
huge 4 inch thick intercooler
stock rb26 intake manifold
nismo GMax twin disc clutch
I am still doing some fine tuning on the car before i run the 606whp tune. I hope to run a 6.7sec.
  • 1 month later...
hey Waldoforce (Congrats).... I had in the past a Supra 2JZ-GTE with similar mods and AEM EMS with 750whp stock internals.
I just want to be sure how many miles did you use your car with stock internals with over 600whp, because I had read too many things about the oil pump failure and I am thinking on almost same mods that you have but Borg Warner S372 intead of your T04Z turbo.
Which oil are you using ?
How many RPMs did you change between gears ?
  • 3 weeks later...
Hi, sorry for the late respond but I just came across this thread.
I am presently running a S14 Silvia with rb26 with stock internals rb26 except for 260 degree cams. To date i have made 606whp, and i am using a garrett T04z turbo.
Do you run 5 speed or 6 speed ?
Very intersting!!
606whp at 26psi with very little mods!!! And with smaller turbo than mine..!
I don't finish my project yet..
I also bought a TOP SECRET SINGLE THROTTLE INTAKE with q45 maf!! :(:):blink:
Are you ok with your Nismo twin plate? How many miles and hard lanuches you did with your twin?
Do you thinking for triple or you are happy with it? Do you suggest me to stay with twin?
I am not sure if my twin can handle the power.
Happy with your skyline gearbox?
What diff you have?
1/8 mile 7 sec means lower than 11sec... something like 10.7!!
UNBELIEVABLE GOOD FOR 450whp!!!
With what tires?
How much you did for the 60foots?
So with 600whp how much I will do?!? :):D :D
And with drag wheels with Mickey Thompson 26-11.5-15 (275-60) ?!? :D :D
SX rulez!! :woot::D
Edited by GreeceS13
Very intersting!!
I also bought a TOP SECRET SINGLE THROTTLE INTAKE with q45 maf!! :whistling::D:P
What diff you have?
With what tires?
So with 600whp how much I will do?!? :D:D:D
And with drag wheels with Mickey Thompson 26-11.5-15 (275-60) ?!? :D:D
SX rulez!! :D:P
any update ? did you tested ?
I havent ran the 600 tune much, only 4 1/8th passes to date. Its true that the RBs are plagued with oil pump failures. I am waiting on a ATI damper pulley (600 plus unit) which will help prevent oil pump failure. It also helps not to rev the motor past 8400 rpms
A friend on mines is using a S474 on his Rb25. Its a lil laggy but it hits hard, but he is still tuning.
I am using 4 quarts of 20w50 Castrol oil with 1 bottle oil lucus oil stablizer.
I shift my car at 8100 rpms, and i drop about 2000 rpms between shift.
  • 1 month later...
GreeceS13 ...... did you tested ? any videos ?
I tested the car using a pair of Mickey Thompson 26*10*15 on 10" weld rims. I blew the factory LSD and da car just spung 1 wheel.
I then weld the stock skyline diff and went back to da track. Unfortunitly the clock wasnt working, but i will say this "OH MY GOD" the car leaves the line like a bat out of hell (2 stepping the car and leaving the line with 18psi of boost). I ran a turbo mustang that run 7.3 sec in the 1/8 and beat him convinsingly, and I was at 20psi of boost.
There is a event coming up on the 31st of this month, so I will have some times and hopefully a vid of the 26psi 600whp run.
how much weight your car ? I am worry about the 3rd gear problem on your stock 5 speed tranny with 606whp....
I don't finish it yet... :D:bunny:
We have summer in Greece now and it is great time for other enjoyments :(
But I have a drag race to run at 13-14 September and I hope to be ready to race.
So I will inform you about the car..
For the time I don't hear the engine to work yet :laugh::down:
I couldn't say for sure what the weight is, but the car is a full body s14 with full interior. Plus my weight is 265 pounds. I would guess about 3300 pounds with me in it.
I have also heard of people breaking 3rd gear with big power on the R33 box in a Skyline. I hope by having sprung hub twin disc clutches (Nismo GMax) will help absorb the SHOCK in 3rd gear. I will see what happens on August 31st, when i really push the car :banana: .
I will keep you all posted.
I have also heard of people breaking 3rd gear with big power on the R33 box in a Skyline. I hope by having sprung hub twin disc clutches (Nismo GMax) will help absorb the SHOCK in 3rd gear. I will see what happens on August 31st, when i really push the car ;) .
Are you running RWD or 4x4 ?
you're OK up to 650whp if is RWD.... my case is worst only 500whp on 4WD.
650whp, well thats good to hear.
Thanks for the heads up.
Oh i just installed my 600plus hp ATI damper pulley, now I am ready for the big races this weekend.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
