Hey ive got LED dash lights i want installed but i have no idea how to do it
i called up an auto electrician and they quoted me some rediculous prices which is not worth the trouble for couple lights...
i live in S.E suburbs just wondering if anyone knows any other places that might do it saving me some $$$$
thanks
https://www.sau.com.au/forums/topic/202402-led-light-installation/
i put some in my 33...Only prob is their short life due to nut being able to handle the same current as the factory globes... but the look cool so its worth it lol
Edited by tm_r33
OK if any of you guys are available tomorro (Tuesday 22nd ) and are willing to come to me...$20 lol...i cant get anywhere im awaiting on some packages from AUS post to be delivered....PM me ASAP if any of you guys can help me out..much appreciated.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
