Got a bit of stuff to get rid of, most of it is pickup only apart for a few of the smaller items that i'm willing to post. Pics of aftermarket gear will be up soon and pics of the stock gear can be provided at request.
Item: R32 GTST 92 model instrument cluster
Price: $100, prefer pickup
Contact: PM me or reply here
Comments: all gauges and lights work. it has 129375.8 km on it.
Item: All the A/C gear from the engine bay off a R32 GTST
Price: $100 for the lot pick up only
Comments: the a/c was working before i removed it, the only problem was the a/c compressor would blow a fuse once every couple of weeks of use.
Item: Powersteering pump and Mounting Bracket and Reservior from R32 GTST
Price: $100 for both pickup only
Comments: good working order. i will sell the pump and reservior separately if needed
Item: Passenger side Headlight for R32 GTST
Comments: Projector headlight in good working order with working bulbs.
Item: No name 3" Turbo back dump/front pipe and X-Force 3" Hiflow Cat
Price: $200 pickup only
Comments: Dump/front pipe has thred for O2 sensor, Cat only 6 months old. i am willing to separte but only want post the cat.
More items up soon, interior trim and stuff.
Edited by QWK32
https://www.sau.com.au/forums/topic/202970-fs-r32-stock-and-aftermarket-parts/
  • 1 month later...
items added, it wont let me edit my posts bu i will upload pics and edit my first post, as soon as i can.
R32 GTST Drivers Side mirror control and window switch. $60 posted.
R32 GTST Power window relay. $40 posted.
R32 GTST Gear stick boot/cover. $25 posted.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
