R32 1993 GTST RB20 Standard Parts
Freight at cost on most parts available
OPEN TO ALL REASONABLE OFFERS
All parts from a running car. Removed as stripping the car for racing
RB20 Turbo complete with elbow $SOLD
Exhaust complete from front, dump, cat and two mufflers. 2.5" Nice and quiet for ADR approval. $200
Air-conditioner parts.
Compressor $120
Radiator $100
Pipes and canistor $200
Front brake calipers complete with pins, clips and shims. Needed to be opened with some force so may need to be re-kitted. $50
Front brake rotors. Need machining. $40
Fan shrowd for radiator. $SOLD
Side mount intercoller and some pipe. $40
Duct. Think it is for standard air box. $50
Standard air box base. No lid or filter. $25
Ignition switch. Works OK but key can be removed in all positions. Plug cut off. Key supplied. $10
HKS idle stabilizer. $30
Air fuel amplifier. $30
Stone guard. $SOLD
Bonnet catch. $20
Bonnet cable. $30
Horns. $10
Support. $15
Central locking actuators. Each $10
Space saver wheel. $80
Set of 4 standard wheels and tyres. 50% tread. $200
Spare wheel cover. $20
Boot rear interior trim. $15
Boot corner trim. $10
Carpet mat. $20
Passenger side front seat. $100
4 x retractable seat belts. Each $100 or for the set. $75
1 x seat belt catch. $20
Centre consule. $75
Gear knob. Split at the seams both sides on top. $5
Rear parcel shelf. $15
Moulded carpet. $50
Roof lining. $30
Sun visors. $15ea
Suicide handles and coat hooks. $10
Interior light. $15
Map reading light. $20
Speaker mounts for front doors. $5
Vents for climate control.
Centre. $20
Left. $10
Right. $10
Rear pillar trims. $20
Assorted bits and pieces from $5
Edited by just_racing
https://www.sau.com.au/forums/topic/203452-r32-1993-gtst-rb20-standard-parts/
do you have the rear seats?
also is the stone guards the ones under the engine?
No back seat when i got the car. Yes stone guard is from the front to under the engine.
do u have a clock spring? (thing inside steering column that make indecator stalk returning) if u do I'd like it delivered to 2250 nsw, how much?
cheers
no sorry still using it.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
