Originally posted by YO880
can you even change the rear guards? arn't they joined to the c pillar and roof?
wouldn't you have to change the front bar if you change the front side guards?
yes you can change the rear guards, you just cut them off, and put new ones on, not as easy as it sounds, but to sum it up that all you do
https://www.sau.com.au/forums/topic/2040-gtr-guards/#findComment-44087
Well mate, I can tell u a bit, cos I did a conversion last year. The guards cost me bout $700-$800 each from Nissan, directly ordered. Because they are the same as the aussie delivered model, R32, dont believe them if they try and charge you freight from Japan when u order them. It wasnt until I had started that I realised that you will also need new guard liners, which I think were $150 each. New GTR indicators to fit the guards are bout $350 a side,again very hard, basically impossible to find second hand.
Im a still trying to work on the side skirts, as due to the flared guard the originals would not fit. I did the front bar and bonnet and grill all original too, so fortunately it all fitted ok.
Another extra cost was the need for spacers for the original wheels as the guards add bout 22mm to each side, so I had to buy 2 sets of those till i found a decent fit.
So be prepared to spend $$$$$$$$$$$$$ on it. Someone reckons mine is only one he knows who have done the whole front end, and I now know why
Good lUCk
Will
https://www.sau.com.au/forums/topic/2040-gtr-guards/#findComment-44158
A friend of mine who is a fibreglasser will be comin around to look at my front gaurds n bonnet as towords the end of the yr we might be going to make a mould off them and make carbon firbre ones. I will keep you posted if i did sell them they would still be pretty expensive due to the cost of material and how long they take to clean up, but ill let you know:)
https://www.sau.com.au/forums/topic/2040-gtr-guards/#findComment-44611
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
