Hey guys just seeing who left in Melbounre has ceffys!! A few mates I knew that had em either sold up or moved interstate- I wouldnt mind another meet up but seriously I know only 1 person with a Registered ceffy at the moment!! Ive owned my Ceff for 18 months and they just keep getting rarer and rarer!
Just wanted to see if any newer ppl on here had accquired any!
https://www.sau.com.au/forums/topic/204004-melbourne-ceffys/
Yeah im in the sth east.
Theres a couple around here as well, i dont know who they are though.
Some asian chick in a white one with 3 spoke advans i think
And i saw another white one that i gave the thumbs up a few times in my ceffy on blackburn road
And i dont know if its still his but i used to see ontryl every day on the way to work
Yeah if people get a few ceffys together im keen to organise a meet up.
Ive met ONTRYL ages ago, dont know who it is.
anticeptik are u the ceffy that came to the hills run in pakenham a few weeks back?
  • 3 weeks later...
I seen that Gold Auto Indulgence ceffy at the RE customs dyno day but no owner.
Who is that and wats the story with that car?
That was my old car. Glad the new owner is looking after it. Its exactly how I sold it.
What story you after about it?
I've still got mine...white autech kitted, that may of been me you saw anticeptik, as i used to drive on blackburn road quite a bit untill recently, now I only drive my car occationly on weekend.
Starionturbo from memory I think our 2 ceffy's are the only ones on carsales in VIC also.....
  • 2 years later...
Spotted an exact replica of my ceffy in Dan_J's driveway.
lol did a double take and almost crashed into your neighbour's car that was parked out the front.
bahaha!
yea finally got it on the road in june, i took the route into your street not too long along just to double check that you still have ur ceffy
spotted a black stock ceffy on stud rd in rowvile a few months back, spotted that white uras kitted ceffy for the 3rd time
also met paul's (Lryder) mate that just got his ceffy on the road.
so shan have you got your ceffy going again?
still runs like a bitch though, the CAM timing's off so it splutters and chokes. Need to get it to a mechanic to get it sorted. Actually might do that next weekend.
If I fix it, I'll sell it tho lol cos I've got too many cars now.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
