nah u will be rite.. just pay attention next time lol..
i was part of the crue that was painting all the shit u see in there and u dont realise, but 60kms is pretty fast.
and those trucks that came thru at night with chickens on em, the smell is fu**in bad.
The Burnley tunnel is such a con! When the traffic get heavy they slow you down by 20km/hr and reduce you into 2 lanes. Sure I know 1 is fro emergency vehicle access should some nuff nuff cause another hindenberg in there. But sh!T how about some forward planing for things like that. :END RANT:
they also slow down the tunnels so that they can clear the fwy of accidents/roadworks furthur up with less traffic... works well, just go around the tunnels :(
Just thought Id add this useless info for the hell of it...It is possible to speed in the Tunnel and get away with it Not that I recommend it by any means. My old boss from my last company hooked up the speed cameras in the tunnel yonks ago. Their are sets of 4 faded black lines that run across the road every 300m or so i think. they are quite difficult to see in a low clearence vehicle, but at these points this is where the cameras are triggered to measure your speed. anyoo.. point of the story is u can go as fast as u want between these points aslong as your at the speed limit when you go over them.
the guys that did the speed cameras in the tunnels is now bankrut you do the math
the strips for the tunnel verisons re pezo strips...just slow down before you get there...make sure you know where they are, use the exit markers as a guide. If you look you can see both the cameras in the gantry and the strips on the road. its not hard.
Not withstanding they are not always on for system maintence (backend) but thats not common.
dont speed is the easy solution.
So its you f**kers that hold me up every night when i go through there.
Piss's me off, pretty much every night (even before they started putting the wall paper up) for the last year the tunnel is reduced to 2 lanes and the speed limit reduced, it should be free when shit like that happens.
Its also a clue to how well it is built, most of the time its shut on saturday nights and there doing other work in there every other night.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
