  • 3 weeks later...
  • Replies 122
Hi all,
Was back for the weekend and was able to get the first shell made. Slight change of plans with the construction, the original box got stuck in the mold so I had to cut the bottom of it out to get the box out. This means that the bottom and the front will both now be 16mm mdf reinforced with fibreglass. I also managed to carpet the original box and it is now installed in my car. It sounds great. Nice deep bass and clean sound. Fits like a glove and looks like it's meant to be there. Took some more crappy pics on my phone and will post them up as soon as I get back, yes sorry to say it but I'm off again. Should be about five weeks and I'm sure you guys are sick of waiting but I will get straight back into it on my return.
Cheers
Ben
Looks awesome. Will you be making one for the left as well? I've been thinking about getting a custom job of taking out the spare and trying to get two 12" in there but this seems like a go-er.
  • 3 weeks later...
  washie said:
does anyone know what is happening with these sub boxes? like when Loftyfang is coming back and finishing them off cause im really interested in buying some.
read it and all will be revealed.
  loftyfang said:
Hi all,
Cheers
Ben
Hi all,
Back for the weekend but away again on monday for a week. After that I'm back for a couple of months so should be able to knock a few boxes out. If there is enough interest in the left hand side box I will consider making a mold for that side too. the only problem is that there's a bracket there for the jack and the areal is there too. Shouldn't be too much of an issue though. I'll start looking into it. Still waiting on a reply from SAU about selling them on here. Will shoot them another pm and see what's happening.
Cheers
Ben
  mikel said:
The F3 (or 3dB cutoff point) is around 48 Hz, not exactly sub woofer territory but not bad.
<snip>
ps I'm not a car audio guru - my knowledge is all in home audio, but the principles of speaker, amplifier and crossover design remain the same
Ditto mate, I designed and built my own hi-fi speakers several years ago. They sound good but I'd make several improvements if I had another crack now.
One thing to remember with car audio is cabin gain. Because of the small volume of the cabin, you get an increasing response as frequency goes down, and this starts to happen around 40-60Hz. So if you have a sub that is flat to 20Hz you will have a ridiculous amount of low bass in your car, it will actually sound like shit.
I think a 10" sub tapering off at 40Hz is ideal for a car. This enclosure looks very promising, I have been tempted to add an amp/sub to the car but not at the expense of boot space. Given the side bit is not really useful anyway I am quite interested in this!! Mounting a 6ch amp a friend gave me will be interesting, might have to make a rear boot partition out of MDF and strap it to that!!
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
