  • Replies 45
forget that. back to pants for me.
anyway, so much talk, so little drinking.
at this stage it looks like fatz, beer baron and kel are the only people hard enough to turn up. oh well, short rounds mean it's easy to carry the beers.
if anyone wants to come along, just do it. we are pretty friendly. especially fatz he is a bit too friendly.
Someone grab me a muffin please ! Dont worry about paying, just say its for Troy :blush:
lol, well there is still plenty of gravy for them considering the $47 tip you gave the bloke last time. granted you did smack him with the first muffin he produced.
anyway, I'm considering this a training session for this weekend. :nyaanyaa:
i've sorted out something to tie my phone to my wrist tonight
...though i'm not so sure i'll need it with Mark not there to sneak it off for some of those private photo sessions he's so good at :nyaanyaa:
so has anyone got my phone?
.... only joking - as I said- it's a tame night when me and my phone make it home in one piece :P
still good fun & thanks for the beers boys :P
can't believe Mark didn't answer your booty call Pete
lost my phone last sunday guys
4 days without one - and loving it!!!
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
