what do you mean they dont line up properly when off???
HAve you seen them first hand?
They look good tho...
Plus imgetting a Power FC so gages are only there to A. look ok and B. to check quickly and if theres a prob check the power fc etc etc
By not lining up properly when OFF i'm refering to the reading not being accurate when the car is turned off. An example is when you turn off the car and the boost gauge needle is supposed to return to 0 (mechanical gauge, electric gauges might not do this). Sometimes it will be below 0 or above, etc... in worst cases (like a splitfire mechanical gauge i had) the meter was pretty much 2-3points below 0. I'm also not refering specifically to autogauge, i'm talking about mechanical gauges in general here.
Yes, I have seen the autogauge shown above first hand and saw a few of the electric gauges getting installed. The good thing about it is that the sensor comes with the gauge and you dont have to buy any controller boxes, its really good value. But again, some of them were not very accurate (not very bad though, i'm just picky).. its a 90 dollar gauge after all.
How are you planning on using the gauges to check the power FC ?
Edited by Scratch
Sorry wasnt being clear... not using the gauges to check power fc.. i meant ill have the gauges in front of me and as soon as i see a slight problem ill forget the gauges and grab the power fc to see whats reali up... if you know what i mean..?
Also since you have seen them in real life 52mm is it a bit small? ive only ever had 60mm ones?
60MM FTW.. less time spent squinting trying to read the gauge = more time spent looking at the road.
but thats a personal thing, hold the 52MM away from you at arms length.. if you cant read it properly at a glance.. dont get it.
^ are you sure that includes boost gauges? i know oil and fuel isnt allowed to be routed through the cabin, and i'm sure most poeple wouldnt want it there either
Yes, in theory if the hose was to split over time, it could pump an air/fuel mixture into the cabin.
i'd lean towards saber rather than autogauge. autogauge have a poor rep with some of their other gauges, and as mentioned, even with the stepper version, its luck of the draw. so it doesnt say much for their quality control / standards. theres no point having a pretty gauge if its not accurate.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
