Thanks for the call :thumbsup:
should be interesting to see what he can do in that amount of time... I can vouch for him and he doesn't f**k around... he implanted a 1GGTE twin turbo into my brothers celica in a weekend, in his dads workshop... Best thing is too he actually communicates with you, if something is missing or f**ked or something is needed, he will let you know asap... he doesn't like to laze about ;)
  • Replies 487
Posted Images
No we aren't doing newcastle, we could help to organise a newcastle entry if there are enough Newcastle peeps that want to enter though :P
PLEASE NOTE THAT IF YOU ARE THINKING OF ENTERING, YOU DO NOT HAVE LONG LEFT!
If enough entrants are not found, we will not be entering this year...
Hey Jess, I still can't confirm my car as entering, I smashed it 3 weeks ago and ever since I've been sourcing a shell and am now in the process of having all the running gear installed into the new one. I don't know what sort of shape she will be in to put on display.
Need 3 more entrants... and no, it's not looking good... not looking good at all...
I find it rather annoying that we can have 13 pages, a long long list of people saying they will definately enter, to have 3 entry forms...
Fantastic effort guys...
now Zilch us SAUers do like a smashed car on display
Im sorry that this has happened and hope you get it fixed up :w00t:
Let us know what you wanna do in a week or two maybe??
lol indeed
it would be a shame if we can't back up to defend our "best club attitude" title
Dam straight Duncan!!
Makes the display a whole lot more interesting..even if it is a "show room" display this year
so whats the deal if we dont get enought people to enter? do we just not bother?
Basically Kuma :P We need 6 cars minimum to display as a club
That's for normal entry, you get a free buddy pass entry if you send the paperwork before the 23rd. Our cut off date was early enough that incase it didn't go ahead, and those that wanted to enter with us still want to enter their cars, they can find someone else to go with...
That being the case, I am extending the entry time til next Friday the 16th of May. After that, if enough entrants are not found, I suppose we will not be doing Auto Salon this year...
This is such a shame and looks like the problem's with SAU NSW have put off entrants for AutoSalon aswell :)
I seriously hope there will be 2 more entrants by the 16th..
Would really like to see and make sure this becomes a SAU NSW tradition!
Need to get Paul to edit his first post I think, need to make this thread sparkle again!!
WE WANT YOUR SKYLINE!!
"ENTER, ENTER ,ENTER ,OI,OI,OI"
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
