  • Replies 46
10g odd to spend...i would go teh 33 aswell....but at the end of the day you will get an average cond 32 and 33.
Whereas you have a little more headroom to play with when buy the s13/180 as you will be able to find a better condition one of either with teh additional cash. Horses for courses....Silvias feel like they are built like shit inside and the engine feels way too rough. Up to u
I have a soft spot for Nissan's S series cars. Having previously owned a s13 silvia and 180, both SR20DET's. They are great little cars to drive, great handling and good responsiveness to mods. A swap to a T28 BB from a JDM s15, Eprom,FMIC running 15psi can safely net 190-200RWKW. Thats great in a 1200kg car. Add a Disco potato,PFC and z32 AFM and u got another 40RWKW . Compared to my 33 GTR they are pretty fuel efficient. In terms of practicality the 180 is better with the lift back, and if u wanna do some dori dori, u can fit more tires/equipment in the back. Go a Type X.
  • 5 months later...
or undo the strut brace put the bike in then lock it down with the strut bar lol then the bike wont go flying everwhere when u slide
and on a side note i would rather go the r32 over the r33 just for the looks wise
r33 are whales in my eyes
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
