Hey.
I just bought a trust sump extension for an rb26dett and my aluminium welder has never done one before
Can anyone post up pics of the final installation and a few internal pics too to make things easier
Got the instructions and there all in japanese
Hope someone can help
https://www.sau.com.au/forums/topic/204773-trust-sump-extension-rb26dett/
I can help. hope he's cheaper than the bloke that welded mine! mine was done in japan and cost a farken bomb. :) It's very important though that it's done right, right angle, etc. right penetration, no leaks. it's not very trickey, but it is very important that it's done spot on. so much so that my tuning house building the motor sub contracted out the welding to a specialist.
Hey.
Vince, if your in Sydney, Dart Automotive can help you.
They welded my Trust sump and several others for SAU members and did an excellent job.
  • 1 month later...
Looking at getting one of these for my new baby and will be hitting the track soon. You guys recommend these? If so where's the best place to get them and what costs am I looking at roughly to get it installed?
install is an engine out job so prob not realistic until you have either stuffed the engine already or are taking it out to do a build
I have had the sump out without taking the Engine out before.
But yes..I agree it may be easier
I don't know how strongly I'd reccomend them. for one they have to be welded to your sump which is quite expensive. and is obviously irreversible. they are also a bit of a compromised design. they also protrude a little lower than I would like.
I chose the trust one as my engine was being built in japan and that is what they were comfortable/familiar with. if I were doing it here I would suggest looking at the hi-octane/hi-energy sump. looks very good and many people have had success with it here.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
