nisspeed bulit my mates motor and he is running 30 psi through it.
Rhemac they do alot of engine work for tillbrooks.
There are quite a few more that i can not think of right now, but speak to cubes, black32 or sky30 as they all have well built rb30 motors.
Lewis Enignes is building my RB30/26det drifter. Ported head, h-beam rods, jun crank collar, the works. Were looking for 350rwkw's to start with then once I get a better oil pump well be able to crank it up some more.
Darren is building a couple of RB30's at the moment so nows a good time to contact him about it.
8391 6125,
Cheers,
Daniel
(website in my sig)
Edited by =premo=
yea lewis, if not lewis, go willal racing, tested and prooven.
i had my forged engine done by Willall racing and they did a great job but im sorry but willall racing dont build motors anymore because Peter hall their skyline engine guy left a while ago, even still they use Nisspeed 2 do all the their machining of the block n head etc so i would go there and have it done, then they take it and get it tuned at Morpowa which are also great tuners coz they are next door, but Willall still tunes cars by Martin
Known Pete Hall for over 20 years from Adelaide Engine days and he really knows his stuff........he's at Outlaw Speed Shop now.
yeah peter is a great guy and was very helpful and know's wat he's talking about wether its skylines or gen 3 v8's
im thinking of getting chris milton at milton engineering to do mine...recommended highly by a mates dad who builds/restores ferraris etc. Take a look at their website and give them a bell to see what their like for yourself.
Yeh Chris is alright, BUT our saloon car has more grunt down a straight line than his.......LOL and my mates old man built the engine!!
I think Tilbrooks old engine builder(don't mistake that with that tool that used to dyno there back in the day) went to JMS to work for a while and is now at Wheelworx!! You could try and see if Joe wants to get him to build you a motor, not sure if they are doing that there or not, I know they have macines to do it!!
My experience is otherwise.
35pounds seat pressure for a performance turbo 24v nissan motor is apparently really really good. NOT :)
Prior to that they set it up so it was floating all over the joint. 15pounds seat; floated from day one.
umm 70pounds is where u want it. They looked at me with a shocked face.
I've had the head off 3 times to sort out the lack of seat pressure that they should have been able to sort from day one.
Speak to Nisspeed, Lewis or Adelaide engines if you want some one to build your motor with experience under their belt.
35pounds seat pressure for a performance turbo 24v nissan motor is apparently really really good. NOT ;)
Bit of a catch 22 situation. My experience with reconditioning heads is that you keep your seat pressures to a minimum unless your running welltite inserts (or similar). Obviously the higher the revving the higher the seat pressure you'll need but some reconditioners have gone overboard with seat pressures in alloy heads and pounded the seats into the head to the point were they have to be removed and have your head welded. Thus said 15 pounds on an 8000rpm motor will just float the valves.
Thats exactly it SLED, minimum seat pressure that works. Which comes down to experience what does.
The RB26 heads run 50lbs seat pressure standard; the rb25 runs very close to that but uses the heavier hydraulic lifters. As you would know heavier valve train requires more seat/open pressure to control the valves.
Mine being setup so loose because they really didn't have any experience with the rb25 head has cost me a lot of money and what really got up my nose is when I sent it back to be fixed up I was charged quite a lot.
Such is life; given time they will get the know how of what does and doesn't work with the rb25 heads.
Typically its known that ~70lbs of seat pressure with the hydraulic rb25 head works very well.
R32Abuser; if you do get a motor built up by them ensure they restrict the oil delivered to the head.
Without a dry sump setup its really the only way to control the oil being dumped in the head and filling your catch can under constant high rpm as without a decent vac setup the oil cannot return to the sump quick enough.
I run a single 1.5mm up front and blocked rear. Works extremely well.
Don't get me wrong Miltons do awesome work; its just a slight lack of experience with one motor type that left me a little unstuck. They are getting in to the drift scene so no doubt a lot of R&D will be done.
In saying all that there is ALWAYS some one who's had a bad run with a workshop from time to time. ;)
The experience wasn't bad just the outcome which has been frustrating when I had to go else where to seek advice and get the problem finally rectified.
That sucks with the issues you had Cubes, you would think they would have had enough experience in that area.
I never really noticed too many probs with too much oil upstairs until I got my mods done and now it seems to be an issue. I've got to organize an air/oil separator.....too many junk catch cans out there unfortunately and I dont know which way to go at the moment.
Yeah I guess its part of modifying; nothing ever goes smoothly. ;)
The biggest worry with dumping oil in the head is if you track the car. Constant high rpm and the oil isn't able to return to the sump quick enough which ultimately results in oil surge. A lot of the blokes get around it by over filling the sump.
Mine was extremely bad as I have close to 90psi over ~4000rpm ish. after a hard pull on the rollers I could see the oil puddling with the lobes slightly poking out the top of the oil. Restricted the oil down and its now spot on.
I run 2 catch cans one either side down low as its neater than having big hoses winding through the engine bay.
Tomei sell oil restrictors but its a pain in the arse pulling the head off for a $5 part.
Kisin and R32Abuser, it may be worth having a chat to Sean at Boostworx. They have tuned and built a few rb30det's; they also get work done by Jason @ Nisspeed.
Sean is well aware of the oiling issues and has had quite a lot done alot of fiddling to get it right.
Yeah I guess its part of modifying; nothing ever goes smoothly. :)
Appreciate the advice :thumbsup:
on my holden v8 speedway motors we used to drill a hole under the valley cover into the timing chain area for the oil to drain back thru and tap into the back of the heads and put a return line back to the sump .
i would have expected somelike like miltons to be more clued up than to make seat presure mistakes .
he has been around a long time i used to race agaisnt him at speedway yrs ago
Yeah I guess its part of modifying; nothing ever goes smoothly. :(
Yeh tell me about it...... In our IPRA car we've chucked a 3SGTE in a RA40 Celica, 3S came out of a Mr2, so in the rear and FWD specs to front founted RWD car, and those engines have a mad lean on them in the Mr2, and we obviously had to straighten it up, Alot of people have had issues with this, as we did early on!!
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
