starlet GT engines are awesome little things. I have one in a mini (old schooler), its not running yet. A couple of people in Aus are have them in minis and running 12sec passes out of the box.... For sure they SNAP my skyline
DRP-OOF - why are you posting in a thread about starlets then?
Monkey - I'm comfortable on my horse..
you two lesbians need to chill out.
Cause I have shit to say... and again, you're defending yourself... stop arcing up so much...
and heaps creative on the letter there... my plates were actually 'modified' once with white-out and a pen :P
So you're not the first...
there is no "factory" supercharged/turbo starlets.
I'm sure it's doable, but would be a lot of money for nothing.
I'm assuming you have the aus delivered shopping trolley version.
you can turbo charge that..
or engine conversion from the jap spaec EP82 starlet which has the 4e-fte turbo 100kw engine.
Sydneykid had once mentioned that he knew of someone who had shoehorned a sivler top 20 valve 4age in to one.
those motors are 118kw I think..
was apparently a bit of fun to throw around.
FYI to the above - there are starlet GT's - turbo from the factory...
i was thinking about buying a turbo stalet a while back. they do a low 15 second 1/4 stock, so a few mods like exhaust, cooler, and more boost and you should be into the low 14's pretty darn easy, and still have a car that you can park in the trolley bay at coles.
thats it hey, can be a nice quick commuter!!
I should have typed that as supercharged+turbocharged.
I initially thought the OP was asking to supercharge his already turbo starlet.
as in, I thought he had a Starlet GT which he also wanted to supercharge.
like twin charge.
make up your mind? or were u implying there were no aus spec turbos?
i had a gt starlet years ago.
ran a 12.9 at wsid on street tyres with only the following mods
trd lsd
new manifold with wrx turbo to suit
full exhaust
fuel reg
fuel pump
dont know bout you guys but for those mods thats pretty dam quick. cheap awesome little car in my opinion
yeh I described what I meant 20 mins before you posted... just above this post.
trd lsd
full exhaust
fuel reg
fuel pump
that was the $5K I was refering to.
got it from Dale? (10secrx7)
he has/had a upgraed package of:
manifold
TD04
Microtech and tune
and a few other bits.
was under $5K from memory and pretty much gave a power/weight to run a 12.xx
then it was a matter of driver ability and traction.
"When threads turn bad..." haha
I rem when my cousin got me into cars, mid 90's. KE Corolla's, Cordia's, NA Rotary's were the bread&butter. 11sec Sigma turbos would eat you, and in cabin, screwdriver tweaked Microtechs was NASA stuff.
Ahh the good ole pre-adolescent 90's; wet dreams, women and umm... worcestershire sauce.
    • I had issues with my car today after removing the rear bumper. The headlights aren't working when turning the stalk but high beams are working and the rear tail light where the reverse camera is wired up won't turn on when the stalk is activated, but the reverse camera, tail light indicator and brake light all seem to work. I checked the fuses they aren't blown. I think the reverse camera could have possibly gotten pinched but shouldn't be as there is a decent amount of room. I did use the lights and loom for the license plate from the new bumper but also tested the old one in case but made no difference. This isn't for a skyline also. Any ideas what it could be? It was working when I drove I'm pretty sure, then on my return home I noticed my headlights weren't working.
    • IMG_6023.mov   In motion 🤙
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
