will the HKS 2835 pro s custom dump fit onto a standard front pipe? or is there modding required?
the turbo's in the mail (well container) and want to know if i should go a hks front pipe or get one fabricated...
https://www.sau.com.au/forums/topic/205182-quickie-on-front-pipes/
