hey all im taking my car over the pits on monday mourning, i have been working on the car all day to get it up to scratch for the pits but forgot to fix me window washer squirter things,
i think the motor is burnt out coz i tried wriggling the wires around and stuff but it wont go, does anyone know where i could get a new washer bottle motor tomorow?
cheers
https://www.sau.com.au/forums/topic/205197-window-washer-squirters/
oh and its a r32 forgot to mention, i dont want to have to take it back over the pits again coz of it,
so yeh if anyone has a spare would i could buy or anywhere prefferbly NOR i could get one would be good, cheers
well im going to warrick, ive heard good and bad things about all the inspections places, to go warrick u have to book in advance and it isnt much time waiting, im choosing warrick coz its the closest and i went there a few weeks ago with me mate "PIMPN33" and his fairly modded r33 got over no probs, i went in last week and had a chat to the head inspector about me car having no back seats, gauges and a 2way lsd and he said it should be no worries and hell write me a permit for hte seats and gauges
wow i went to welshpool and i asked for permits and they gave me a form to fill out and so on. also if some of you guys go to welshpool better to go around lunch time cause they will hardly any cars there, i know some people think is better to go earlier but they are just way too many cars infront
haha i once got pulled over for speeding in the stock patrol with 33inch tyres (perfectly legal) and got yellow sticker for having a too big lift kit and tyres, went to welshpool and the inspector was being a dickhead coz somehow on his computer he found out that i was speeding and then he told me off and said im only allowed to have 31inch tyres on and made a list of stupid shit, next week dad took the patrol over the pits near the city and they passed it without us changing anything on the car
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
