  • 1 month later...
  • Replies 62
have u slamed it yet mate
just thought i do ya a quick pic of what it could look like with the right height suspension.Hope ya like it mate
Edited by Travis32
And you dont have any rubbing problems???? Do you have your guards rolled?
Lol i wouldnt say that :ermm:
I do scrub sometimes over large bumps, tight corners etc, however if my car werent so low, i would have no troubles at all.
So dont slam it as low and you will be fine :) plus its not the offset thats causing the rubbing, its hitting my plastic inner guard liners.
Its just too low, the rims themselves are a nice fit i think ;)
