  • Replies 118
Hi Sean,
Is this a series 1? If so, do you have the plastic key hole cover as below? (Or if you know it'll fit a series 1)
Sold already, popular item sorry.
  • 2 months later...
  • 2 months later...
hey mate not entirely sure if u still have anything from the car or even if u still have the car at all..... but i was interested in the cooler piping that goes into the plenum in particular the pipe with the bov adapter and plumb back setup and how much u were after for it if ur interested in selling it..... also where abouts in sydney are u for pick up of parts???
PM SENT
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
