ah yes tram lines :/ No wasnt me im up near Richmond primary school at that time
it was my evil twin the one that does naughty shit :D << lol i made that up sounds good eh
Ah yes, the evil twin. I have one of those :wave:
saw luke with 34 4 door tonight, spotted the 34 lights from a mile away when you pulled out of kmart on anzacs then watched the puzzled look you had for a few seconds when a falcon with a SAU sticker pulled up next to you lol :wave:
Car looks tough cruising along man. I remembered back to first time i saw it, stock everything, soooo much better now.
Saw DSTROY and a silver over gunmetal 33 turning onto hindley st off king william about 45 mins ago.
seen luke too...........and he come back into kmart LOL
was there checkin out the "commola"................flick and luke would remember this car from the old days at gardens........
its back..........and supercharged this time :/
girlfriend saw EVIL33 driving behind her today on the way to my house
we also spotted a red 34 with a black bonnet with a chick driving it.
and a maroon 33 turning at the maccas intersection at TTP this arvo looked pretty good!!!
Spotted a few cars around today....
Silver stagea at parafield car wash...SIKR33 or something along those lines on south road around 12.30..White S2 R33 with FMIC and stockies on the back that was sledded on south road near mitsi's, another white S2 R33 with RH9 (or was it RH1) plates on it near arndale and a black R34 at domino's near arndale.....
Luke ENR34 at richmond rd / grove av lights a bit before 4 this arvo, did toot................was in the truck on the way back to the depot
and i reckon i spotted PK, Kellie, Chad and Steve at Aussie Pizza House.............not sure tho :blink:
Spotted a scotty's black 32, minh's silver 32, chad and DSTROY, adam and his silver 4 door 32, adrian and his 32, my 34, kellie and her 33, steve and his 33 and ryan with the 33 at my dads work today! Had a good day, learnt alot about cars. intercoolers are harder than they look, LED's are easy to fit into guage clusters and pizza takes an hour from wingfield haha.
hahahaha u were there DAMO??
and the pizza! god kellie should never get a job as a pizza delivery person! she sucks at it! and yes was a great day! even though not much got done! hahaha
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
