^it is very intimidating i must admit, when i was at villi's i hanged around out front and talked to a few people but you guys sit round a table in a closed off section and to walk into the middle of that and be like "heeyyyy im from sau" is a bit intimidating to start off with, im sure your all great people tho :nyaanyaa:
Yeah I know what you mean, but there's usually a couple of SAU folk that'll always make an effort to include you.
You'd be surprised how many in that group are relatively new and feel the same way you do, cheers
^^ that might of been the end of Fabio's cruise had a good turn out at the meet spott
I saw one cefiro, couple of skylines and the rest were other cars like wrx etc. there was even one golf.
It looked more like a street race than a cruise tho...
Anyway spotted PHNTOM Supra getting owned by my r32 on north terrace couple of hours ago. The owner obviously put all the money in exterior and none in the engine...  :thanks:
Then soon after that spotted 2 r32s at HQ turning toward west terrace and a nice black stag on my other side.
Edited by Rocky88
spotted a silver 33 gtst near hollywood plaza about 1ish today , gave driver a wave n got one back
also spotted RB033 or something similar in paralowie about 8pm
haha that was me in the silver 33, nice skyline you got there!
also saw a red r34 gtt in parafield gardens today :thanks:
from memory phntom is na i was entered in the toyoshow 2 years ago and it was there
yea checked net and its na... it was just too easy lol
But hey, it does look good tho...  :thanks:
Here's the pic i found
Edited by Rocky88
ahh yes , now i remember the rego plate :thanks:
yeah mine is alright , lacks rims and coilovers , not to mention power haha
your 33 is mint :P
YOU BETTER BELIEVE IT
yeah i seen this parked on rundle last night bout 11:30pm,down the end other side accross from stag,looking sexy sitting there, coudnt see the owner though :thanks:
dayum, 35s in our presence :thanks:
i reckon i spotted muirsky's 32 parked at BP Brighton the other morning................grey(ish) 32 with white 6 spoke wheels?
Me? Brighton? Hmmm I don't think it was me?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
