Spotted a midnight purple 33GTR with the plates vspec.
Also spotted a maroon 32 with black centered dished rims at the car wash on North East Road.
Ahh the v spec was at autosalon
e27c610_thb.JPG Darrell
VSPEC Nissan R33 GTR Straight 6 Yes427 kW
Autosalon Adelaide Round 4 08
Black R32 with R33 stockies and a front mount near Heights High School - if you're on here, get yourself a thermo-fan, stat. The thing sounds like a VK Commodore.
Edited by Iron Chef
spotted the vange mobile next to sinergy today.! and a white 33 with an sau sticker on the top right of the windscreen. also MIKES S2 stagea out the front of his work im guessing... looks sweet! parked fairly vip :mellow: haha
spotted DARE YA's 33 yesterday lunch time on south rd, was me next to ya
Spotted him at his work last night, first time he's been there in ages, unless he has a daily. Where ya been simon, havnt driven past in ages LOL!
Also keep seein g a black R32 GTS't going south down south road near the tram line, see ya a few nights a week, when im not with the gf. Has BB plates and the 2 outside rear lights off/unplugged. Anyone on here?
Also keep seeing a black R32 GTS't going south down south road near the tram line, see ya a few nights a week, when im not with the gf. Has BB plates and the 2 outside rear lights off/unplugged. Anyone on here?
Spotted a maroon s1 with an s2 spoiler go past work this afternoon (melrose park/ edwardstown area..).
I was in my hilux, Its bright red and covered in chrome, hard to miss it if you see it around.
You don't drive down Daws road just before seven some mornings do you?
yeah heslo wasnt gona say as part of the spotted rules
but you dont get much more don't f*ck with our cars than the ASC locked fence around cars, sercurity camera's and guards watching over the cams
don't actually take my car there but thats more of a dont wanna drive it while im half awake to leave it in the sun all day and i hear sea breeze rusts ya paint, plus 4wd drives in the morn don't f with me cause im in a $300 that will do a hell of lot more damage to their car then mine :(
n yes i know im a wuss with my GTR :mellow:
also spotted blue32 with gtr wing on the way to work in the morn, it was like am i sure mine's still at home :rant:
Edited by Inline 6
If its at about 5:30 ish then thats probably me
sounds like my car...except for the gtst part....havent got the turbo...yet haha. ill keep an eye out for ya next time
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
