Spotted a white 34GTT going down henley beach this morning, looked over to my left and there he was, drving along side me....oh wait...that was my reflection....
was the double post a reflection as well for added emphasis :cheers:
....uoıʇɔǝ1ɟǝɹ ʎɯ sɐʍ ʇɐɥʇ...ʇıɐʍ ɥo....ǝɯ ǝpıs buo1ɐ buıʌɹp 'sɐʍ ǝɥ ǝɹǝɥʇ puɐ ʇɟǝ1 ʎɯ oʇ ɹǝʌo pǝʞoo1 'buıuɹoɯ sıɥʇ ɥɔɐǝq ʎǝ1uǝɥ uʍop buıob ʇʇb43 ǝʇıɥʍ ɐ pǝʇʇods.
Spotted Black R34, Silver Starcorp's going down McIntyre this morning, Also Maroon R33 S1 on Salisbury Hwy this morning with Huge shopping list & NISMO Stickers all over it... Anyone on here??
Edited by S13_DriftR
Spotted OH SNAP as well.. peter, i think? Saw a dark silver stag on Anzac Hwy.. Also was driving next to this red (turbo?) saab just in front of the other stag, that was trying to grab our attention.. turns out it was chef_stagea trying to get our attention! lol...i tend to ignore european cars ;)
haha yeah that would be adam in his old mans little beast :D
spotted the 'ON SNAP' Stagea turning out a side street on brighton road this arvo bout 6ish, we were in the white ford with the SAU stickers, reckon u might have seen us? Sporting some new, familiar rims on the ford now..
nah didn't see you guys, once again we were heading back from the beach :D practically live down there in summer hahaha
Spotted who I though to be Jasmine (Jas033) at the Golden Grove BP this morning. If it was you, hi! I would have stopped to talk but it seemed as if the police patrol car had more than a passing interest in my car so I left asap
Lol it was!!! I seen them pull in so didnt really want to start a conversation haha would of been a GREAT start to the morning if they got to you!!
ok spotted a few lines and stags in the last 24 hours.
- dark blue/black stag behind me yesterday arvo about 4.15 coming out of gg village going down the golden way
- blue R34 GTR turned off NE road onto McIntyre about 5 minutes later
- white 33 a little further down NE road towards the city
- gun metal grey 32 in the ttp car park near the coles parcel pick up about 1pm today
- white stag nearby in the same car park.
and then its not a skyline or a stag but made me go WTF? about 2.30 leaving the plaza near hungry jacks a white EL/EF falcon with a green CE lancer spoiler? looked terrible as it was way to small for the car. anyone else seen this around?
when you see it, youll shit bricks.
:D jeez don't oversell it! It's making its show debut at All Japan Day - see the thread in the events section for more details. Then those of you who haven't seen it yet can find out what's under the bonnet ;)
Howie..... ¡¡¡buıʎouuɐ uɯɐp os s,ʇɐɥʇ
Spotted this at 3.30p on Southern Expressway.... nice. Makes me wish i never sold mine.
Edited by 32godzilla
ahh thought u mightve seen the SAU sticker or the White Impul rims the ford is now repping lol. Keep seeing stageas everywhere, makes me realllly want mine (cos I WILL own one within the next few years)...
Spotted I think it was HVN 32 behind me in the backstreets of Mile end this arvo just after 5?
Was hoping u would follow so i could give u the calender finally, then I realised I actually have yours in my car!! Shouldve waved you over. I did wave aswell, not sure if u saw me tho? Was trying to race home cos the fuel light was flashing at me!
Spotted a Black R34 at the playground outside port noarlunga, was thinking of pulling in and seeing who's it was and having a talk...but i was on my way home from work and didnt want to freak anyone out, i might have if i knew the person/had met them before.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
