Spotted a silver 34 - 4 door heading out of Victor, Sunday about 4:00 ish. (I was in the black 32 gtr)
Spewing i missed the cruise, got stuck drunk in town and needed time to sober up ><
Spotted a white 32 with white starcorps i think, had white centre with polished lip/dish, on North East Road last night, Had a large SAU sticker on the right rear quarter.
spotted DOHMAR in his 32 GTR driving down North East Road around 5pm yesterday
I saw a white 33 driving down north east road along side me... was that you? Turning out from Galway ave?
-D
Hey mate, that was me. Gave you a small thumbs up. Was luckily enough to not get picked on in the rbt they had set up.
Spotted [TAKEN] Driving down *ahhh I forget* on the way back down from Victor Harbour on Sundays cruise.
Notttt bad!!
She a member on here???
Edited by MR.RB30ET
spotted a real clean Silver r33 heading towards aldinga, with a cop two cars behind him and a bike cop not far from that one and speeding up ?anyone here
guy was wearing a fluro shirt driving it?
spotted a r34 4dr in black on south rd
spotted a r34/white with chromies and full kit and no wing in christie downs,then turned the corner and a wine r33 was a block down on elizabeth rd, the 34 looked like damo's car ?
spotted a nice yellow silvia R spec with nsw plates in seaford, older lady driving it, custom rego ooh aah
a white rx7(about a 90 model) boosting like mad in seaford, heaps of flutter
Edited by sapphiregraphics
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
