Anybody on here own the midnight purple r34 GTR that's off it's nut? Ryan saw it at the hobby shop the other day at Brahma Lodge and reckons he heard it go past his house on Waterloo Cnr Rd about an hour ago.
:glare: to Cara :( sort of surprised and scared you hey :bunny:
haha yeah just a bit..........when i first looked i was like! hey i know that person! lol foot on the brake! hahaha
tonight spotted......
carl :P
damo
chris
krishey
scott
chad
dan
troy
vu
alex
luke
and i think there were a couple at vilis i didnt recognise...........
as rude as is sounds which one were you? :P
and why u not enter your car in to Old School N New Age??? lol
Yeah, thats me, was the one on Krishy's right in the blue t shirt :glare:
I would have entered, but im fussy and just dont think mine is up the standard.
Edited by Jamesrb25
spotted the clan at the clubhouse :glare: ..lol
and the yellow R33 GTST in seaford again,, pulled up behind me while I was at the ATM and boosted it a few dozen times in neutral to show off.. :P then took off, bet his motor is dead or the car written off in a week at that rate....lol
spotted a tool doing doughnuts in the middle of south road at victor turnoff WTF????? (in a Bogan UTE).. only to be pulled over 30 seconds later...HAHAHAHAAH complete idiot !!!
everyone enter the show,, support SAU even if your car isnt a show car...we dont mind :( we need the numbers to overcome the commo horde,
the gene pool needs more clorine(jap cars) to even out the bogan ratio and the prego 13 yr old 1st cousin's....lol
Edited by sapphiregraphics
carl :glare:
damo
chris
krishey
scott
chad
dan
troy
vu
alex
luke
were am i??? not happy!
spotted an absolutely nuts black r34 gtr in front of my house today.. was pulling out of the driveway and he must have wanted to show off. gunned it past me with lots of wheel spinnage goodness. bit of a dumb thing doing it in a residential area but daaayyymm made my day :glare:
Edited by tx3_90
Hes obviously driven the car hard. 34 rb26's are a lot tougher than the 32 rb26's, and if the guy is driving around with smoke coming out the back i doubt hes really taking good care of that car... shame
What is blue smoke from anyhow? Blown turbo? Oil in the combustion chamber?
-D
The plates are V (vic symbol) SPEC 34.... from what i understand its 1 of, or gt georges mate. lives with him.
he saw me and kidafa in the stagea other day and gunned it past us. sounds sick
saw a red hilux with chromies and a sau sticker onit on brighton rd yesterday.
i was in the pig looking dark blue silvia.
That was me, i thought that might have been your drift pig, i seen a few pics of it at lala.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
