spotted james in the 'R on main north, city bound nearish the shopping city at gepps.
wouldve waved, but it took me a f**kin long while to figure out it was you. lol.
Twas i Dave, dont worry took me a while to figure it was you too mate. 200 looks damn sweet on the road mate :D
spotted a silver 33 with bbs mesh wheels turning at morphett / seacombe road roundabout this arvo about 2
Sounds like that was me in the silver 33 but I was going through that roundabout closer to 3pm :blush:
Sounds like that was me in the silver 33 but I was going through that roundabout closer to 3pm :)
might have been 3, i was losing track of time yesterday haha
i was waiting to turn onto seacombe road in the patrol, wouldnt have been hard to miss it :blush: didnt know that you lived in my neck of the woods :(
White 33, possibly a GTR turning right from Brighton Road onto Sturt Road, had dark coloured rims. Looked tough from the front..
And also a wine red 33 in the BP further south of Sturt Road, not the one on the corner, but further south.
And a stock grey 32 with BB plates stopped on Brighton Road.
All this morning around 9.30.
Spotted C U BYE (33) in Pultney St Saturday night.
And a Black 4 door 33 with Red rims? Very different.
Oh and a Silver 32 with twin straight pipes hanging out on Light Square Saturday night... Noticed you were shitting yourself/shifting into 5th gear at 20k/h while the cop was next to you lol
saw a white r33 broken down on main nth rd nr midway guy standing next too it was on the ph i couldnt stop i was on the opposite side taking the mrs to work .
hope you got it all sorted out
Edited by mid life crisis
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
