A sexy orange supra with a black bonnet on the freeway right near Mt barker at 9.30am
Sounds like Maccas supra.. He changes between 18inch roh alloy 5spoke no dish.. Or 18 chromes with tiny dish on front and chucky dish on back! Fair bit of orange in the inside to! He painted it him self.. :thumbsup:
Oh and sumtimes has the orange bonnet on it.. Got the now
Black one from a wrecker.. It was white and needed lots of love! Lol
Lol =) it looked like a nice orange it was going down the freeway and I was going up the freeway lol but didn't see what rims it was rolling!
Spotted some Skylines out the front of the North Adelaide bakery last night, red R34 and a White (? memory a bit fussy, we'd just come from the pub) R32 with lots of stickers. I love that place :D
been in Adelaide over the weekend for the soccer from Melbourne, seen some mint skylines here too many to remember specifics :) anyone been around hindely st then I've probably seen you, nice cars guys
Probably spotted you at Hindmarsh then :P
black R34 no wing , dinga shops, gave a wave got a dirty look. then same car at 120am doing a quick fang and skid past my place. DONT DO IT AGAIN.
pearl white stag at dinga petrol station just now.
looked at a red R31 on south rd between sellicks/dinga , for a daily, damn thing had a missing number on the phone number. DOOH!!! anyone know whos car it is Im keen?. noticed it had a fine on it as well.. lol
spotted Sherlock headed north on Pt Wakefield Road past the Mallala turnoff about 1 this arvo. Was headed southbound in the small Army convoy (couldnt hit the airhorn quick enough :laugh:)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
